Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
03 cobra suspension
Old 09-14-2005, 08:13 PM
v8musclecobra
v8musclecobra's Avatar
Default 03 cobra suspension
is there any way to stiffen an 03-04 cobra's irs enough where it works just as good as a live rear axel, cause ive heard a live rear axel is a very rough and unenjoyable ride.
v8musclecobra is offline
Old 09-14-2005, 08:22 PM
IWinULose
IWinULose's Avatar
Default RE: 03 cobra suspension
ORIGINAL: v8musclecobra
I have no complaints about any live axle car I've had. As far as your question... Say you take an IRS and stiffen it... make it almost to where it won't move... What have you done besides create live axle? I think you pick one. Either IRS(better ride) or live axle(for more horsepower and better launches). It seems to me like you would be defeating the purpose of the IRS if you started decreasing its flex and stiffening it. But that's just my opinion.
IWinULose is offline
Old 09-14-2005, 08:28 PM
jdaniel
I ♥ Acer
jdaniel's Avatar
To answer your question, you can buy the IRS brace and bushings and that will allow you to run it a lot harder from a dig and will definetly give you better traction because it wont flex as hard.
jdaniel is offline
Old 09-14-2005, 08:46 PM
Fallstar01
Fallstar01's Avatar
There are a number of products that are aimed at doing this.
From what I hear, the kenny brown setup is the mother of them all and it's pretty darn expensive but it's supposedly the best irs set up, bar none. It's also the only that actually replaces the upper and lower control arms (not just bushings).
Kenny Brown's website is crap and continuously under construction so you're best off searching google for more information. Here is an article I found:
http://www.allfordmustangs.com/artma...icle_383.shtml
Steeda has some kind of roll steer kit and some bushings and brakets:
http://www.steeda.com/store/-catalog/555-2155.htm
http://www.steeda.com/store/-catalog..._steer_kit.htm
Maximum Motorsports has a bunch of stuff that are all summed up in these kits: (http://www.maximummotorsports.com/giabIRS.asp
The links below currently do not have IRS setups (to the best of my knowledge) but could in the future since they are known for their live axel setups:
Griggs Racing: http://www.griggsracing.com/
Evolution motorsports: http://www.evolutionmsport.com/
Fallstar01 is offline
Old 09-14-2005, 08:55 PM
v8musclecobra
Can you still run low 9 sec quarters with the stiffened irs. You do have a point that it basically is a live axel whaen you stiffen it that much...so which for the money and power, do you think id be better off with? The kenne brown seemed real good that it was also 40% lighter.
Old 09-14-2005, 11:09 PM
Fallstar01
Fallstar01's Avatar
From my understanding, the kenny brown owns all. I've heard that under certain sanctioned events, it doesn't qualify for some reason, (i'm paraphrasing stuff I've read elsewhere so correct me if I'm wrong people), which is why you typically hear more about live-axels tearing it up.
Lets put it this way, if I had a huge budget, I'd probably swap out my live-axel for the Kenny Brown IRS.
Old 09-14-2005, 11:29 PM
v8musclecobra
how expensive are they then?? i didnt see a price but this is an on going project as you all know and money is no object cause it's a project car and isn't getting done all at once.
Old 09-14-2005, 11:58 PM
Fallstar01
Fallstar01's Avatar
http://www.kennybrown.com/shopkb.cfm
Call Kenny and ask (317.247.5320). Be sure to post the price here for other interested folks.
Old 09-15-2005, 12:32 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
I would like to know what the IRS brace and bushings cost from KennyBrown. I think thats the ones that my buddy got and he got it all for like $300.
jdaniel is offline
Old 09-15-2005, 08:26 PM
v8musclecobra
called but got no answer. does anyone know if its under 3 grand for full front and back suspension.
Lethaldosage423
10-19-2015 12:12 AM
88 orangepeel notch
10-05-2015 09:03 AM
Matt's 95 Stang
10-05-2015 07:16 AM
UrS4
09-30-2015 10:13 AM
marc954
09-29-2015 11:18 AM
Quick Reply: 03 cobra suspension
