Rattle in exhaust note?
I've noticed a strange "metal rattle" noise at 3krpm. I thought I knew what the problem was.. I had a blow-through code popping up for my driver side cat. I have full Bassani on the car, so they replaced the faulty cat at no charge (lifetime warranty ftw). The new cat was put on while the car was apart having a new clutch put in.
The code is gone.
But the noise remains.
Now every time the car hits 2900-3100 rpm, the exhaust makes an odd metal rattling noise. Not like a bad exhaust hanger, that causes more of a metal-knocking-on-metal noise due to your exhaust pipe hitting the frame (usually).. But imaging putting a coin on a metal trash can lid, then putting that on top of a sub woofer.. a strange harmonic-metal-rattle is the best I can describe it. and it is ONLY around 3krpm. Doesn't do it any other time, not on start up or a 2krpm or even at 5krpm...weird..
The only other thing I can think of is bad welds around the muffler that may be vibrating when I hit a certain exhaust note.
The code is gone.
09-24-2015 09:18 PM
