Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Bogs down when NOS is on
Old 04-01-2012, 09:24 PM
prboi4evr
prboi4evr's Avatar
Angry Bogs down when NOS is on
Car drives strong and when i turn the NOS on the thing just bogs down big time like if it was flooded or something... i checked the bottle and its full on NOS sprays strong i check the line to the intake because its a wet shot and full seam to be coming out of the sprayer only idk what i could be there doesnt seam to be any leaks just the NOS isnt getting through just gas coming out of the line...
prboi4evr is offline
Old 04-03-2012, 02:03 AM
jimkaray
jimkaray's Avatar
You should provide more detail on your set so we can make a more informed assessment. But from what I interpret from the post I'm going to suspect plug gap. What gap are you running? Should be between .030 to .035
jimkaray is offline
Old 04-04-2012, 06:44 PM
nitrous_bob
nitrous_bob's Avatar
did you use a brand new kit ? or used ?
if nitrous is flowing thu the linbe...it'll be icy cuz its about -500*
if the suction tube is oriented incorrectly you'll just get vapor and no liquid nitrous
if the bottle is new...it'll be oriented so that with the label str8 up the tube is at the bottom on the bottom of the tank
if it was used...it might be drawing from somewhere else
with the car off...key on...you should be able to activate it and see if it flows from the line...use a heavy glove and hold on tight
what activation method are you using ?
nitrous_bob is offline
6bangr
02-15-2016 07:40 AM
Seanam
10-04-2015 10:15 AM
Daddys Girls GTs
09-14-2015 08:46 PM
Lee1911
09-01-2015 02:12 PM
GimpyHSHS
08-29-2015 06:30 PM
Quick Reply: Bogs down when NOS is on
