i wanna build a turbo 5.0 DD thats reliable
well i have a 1991 foxbody that's my weekend warrior/DD and im thinking about turbo charging it but i want reliable kit and a non grenade motor waiting to blow up. ON3 is a cheap kit is it any good? and what do i need to do to my motor for it to be a reliable DD?
there is nothing you can do to a stock motor to make it stronger. the block it self literally splits in half when you hit a certain hp/rpm. you can fill all the coolant passages with cement but with no water in the motor it will only be good for about 5, maybe 10min at a time. then youll have to shut if off and let it cool
HP is expensive
HP is expensive
HP is expensive
You can run it with low boost on the stock shortblock without any issues. I wouldn't advise searching for 400+ hp numbers & expect it to stay reliable for long. I agree with luckythirteen13 on the On3 kits
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
09-25-2015 09:06 AM
