blow off valve on s/c
I HAVE A POWERDYNE S/C AND ITS MAKES 8 PSI I WAS WONDERING CAN I PUT SOME KIND OF BLOW OFF VAULVE ON IT ANY KIND AT ALL? ALSO I HAVE AN AUTOMATIC WITH 4:10 HOW GOOD WOULD IT DO ME TO GET A TORQUE CONVERTER? HOW MUCH WOULD I LOOSE IN MY TIME?
97GT CONVERTABLE/AUTOMATIC
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
13.9 WITH 2.078 60FT AT 97MPH(NO TUNE/ NO EXHAUST/ ON USED STREET TIRES)
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
RE: blow off valve on s/c
You can put a BOV on any kind of turbine forced induction(Not sure about screw types, etc). It won't help performance but should help release the unnecesary pressure from the turbine. Also, unless you can somehow tune for the change in airflow to the engine when it releases the pressure you have a good chance of shooting flames out of your exhaust from an extremely rich condition.
ORIGINAL: ScreamingYellow
ORIGINAL: catchds
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
ORIGINAL: 02StanGT
I see in your sig you don't have a tune. Don't you think you might need one? Or does your car run just fine?
ORIGINAL: catchds
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
4:10 GEARS
POWERDYNE S/C 8PSI
DEIOBLO CHIP
I FOUND THAT THEY MAKE ALL KINDS OF BOVS THAT ARE UNIVERSAL AND WILL TAKE THE PLACS OF MY BYPASS VALVE AND WONT MAKE MY CAR RUNNING FUNNY AT IDLE. THE ONE I AM GETTING IS MADE BY HKS SSQV SUPER SEUQCHAL BLOW OFF VALVE AND IS ONLY ABOUT 150$
POWERDYNE S/C
4:10 GEARS
DEOBLO CHIP(NOT TUNNED)
AUTOMATIC
POWERDYNE S/C
4:10 GEARS
AUTOMATIC
ORIGINAL: catchds
POWERDYNE S/C
4:10 GEARS
AUTOMATIC
POWERDYNE S/C
4:10 GEARS
AUTOMATIC
