Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
supercharger problem no boost - pls HELP
Old 07-28-2013, 12:10 PM
plo_luv
plo_luv's Avatar
Default supercharger problem no boost - pls HELP
i'm having a problem. at idle the gauge is showing vac, and when i drive it or rev it up the gauge will only go to 0, no boost. nothing is wrong with the gauge so i'm having a vaccum problem?? anyone had any problems like this??
pleaase help.
plo_luv is offline
Old 08-09-2013, 07:18 PM
15austin
15austin's Avatar
Bypass valve stuck open maybe??
15austin is offline
Old 10-07-2013, 08:15 AM
millertime4060
millertime4060's Avatar
mine was doing pretty much the same thing... i put a new belt on, mine was slipping..not sure how old yours is, but mite be worth checking
millertime4060 is offline
Old 10-20-2013, 04:55 PM
uberstang1
Chupacabra
uberstang1's Avatar
Belt slip, bypass valve, ignition issue, could be a ton of things, is it breaking up?
uberstang1 is offline
Galactic
04-29-2019 02:56 PM
ernesto-619
09-10-2015 01:32 AM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
Quick Reply: supercharger problem no boost - pls HELP
