boost questions - MustangForums.com
Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Sponsored by:
Sponsored by:
Old 06-26-2014, 12:18 PM   #1
OKIEMUSTANG
Default boost questions
i have a 95 mustang with a vortech v2 supercharger system. i just installed a cheap dragon gauge, and it gets -9 during idle. I drove it yesterday, and i had to almost redline to get the boost to register 3-4 psi. this is suppose to be set up 6-7psi. the sheave on the supercharger looks to be about 3.5" diameter.
Does this seem right?
OKIEMUSTANG is offline   Reply With Quote
Old 06-26-2014, 03:13 PM   #2
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
boost section please....moved ...... op check belt tension, must be tight to play a tune on it....flick it to make it play a tune on the long side.
mjr46 is offline   Reply With Quote
Old 06-26-2014, 03:25 PM   #3
OKIEMUSTANG
Quote:
ok thanks, wasnt aware of the boost area.
Interesting didnt even think of the tension. it seemed tight, but maybe not tight enough? i thought the tensioner keeps it tight?
thanks for the help!
Old 06-26-2014, 06:16 PM   #4
CPTCO
Where in OK are you located? Shot in the dark, your kit would be at 6-7 psi at sea level. But some places in OK are around 3500 ft in elevation.
I ran into the same problem here in CO, a smaller pulley on my TVS fixed that problem.
CPTCO is online now   Reply With Quote
Old 06-26-2014, 07:07 PM   #5
OKIEMUSTANG
I'm probably under 1500' I'm in Norman ok.
Old 06-27-2014, 12:10 PM   #6
mjr46
mjr46's Avatar
is it an automatic tensioner or manual tensioner??
Snow performance stage 2 MAF boos cooler install jwog666 Pipes, Boost & Juice 5 04-04-2016 05:23 PM
TNT, New PB TCStangerv6 Street/Strip 12 10-11-2015 06:57 PM
Win $1500 Worth of RTR Parts - AmericanMuscle AMAlexLazarus AmericanMuscle.com 3 10-02-2015 09:06 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
Hello, new user with an older Mustang and a question treesloth New Member Area 4 09-28-2015 08:03 AM
