Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-03-2007, 12:30 AM   #11
Jexey
Vehicle: 98 GT
Default RE: Positive Displacement Superchargers
bump, yo
__________________
White 2v 98 /w Full 10% Tints, black torque thrusts. Full cervini stalker body kit. Full bolt ons, PI swap, black interior swap. Work_In_Progress!
Jexey is offline   Reply With Quote
Old 07-04-2007, 01:42 AM   #12
PJinIA
Default RE: Positive Displacement Supercharger Info
What I want to know is there any other twin screw for a 5.0 besides the KB. I don't like the way the KB hangs over to the side. I want something that sits in the center of the motor and is capable of 15-20lb of boost but with a pully change I can run around9 lbfor the street.
__________________
86 GT
Mass Air
King Cobra Clutch
Eibach Pro Kit
Tokico Shocks and Struts
MAC Caster/Camber
MAC Fenderwell Cold Air Kit
16 Cobra R
MAC Headers
Off Road X Pipe
3" Tail pipes
Hurst Lineloc
3.73
PJinIA is offline   Reply With Quote
Old 08-14-2007, 03:31 PM   #13
Mr.Bape
2007 Ford Mustang
Vehicle: 2007 Mustang
so if I'm installing a supercharger in my v6 07 stang, I should go with whipple or kenne bell instead of vortech?
Mr.Bape is offline   Reply With Quote
Old 09-29-2007, 04:40 PM   #14
LaStang04
Another interesting fact about roots type blowers for the younger crowd ( yes i'm an old geezer compared to alot ) . The first Roots type blowers were acually taken off diesel engines and adapted to fit on gasoline engines. Thus the ones you will find being called 4-71, 6-71, 8-71 and so on , those were taken off Detoit Diesel (GM--Gray Marine)engines and new drive housings made to run off a belt. Roots type blowers were around long before World War 2 on deisel engine applications.
__________________
04 Mustang
3.9 Liter
Auto Trans
Lowered 1.5 inches front and rear
LaStang04 is offline   Reply With Quote
Old 11-01-2007, 12:03 PM   #15
galin
Getting more fuel into the charge would make for a more powerful explosion. But you can't simply pump more fuel into the engine because an exact amount of oxygen is required to burn a given amount of fuel. This chemically correct mixture -- 14 parts air to one part fuel -- is essential for an engine to operate efficiently. The bottom line: To put in more fuel, you have to put in more air. That's the job of the supercharger. Superchargers increase intake by compressing air above atmospheric pressure, without creating a vacuum. This forces more air into the engine, providing a "boost." With the additional air in the boost, more fuel can be added to the charge, and the power of the engine is increased. Supercharging adds an average of 46 percent more horsepower and 31 percent more torque. In high-altitude situations, where engine performance deteriorates because the air has low density and pressure, a supercharger delivers higher-pressure air to the engine so it can operate optimally.----drug rehab
galin is offline   Reply With Quote
Old 04-28-2009, 03:27 AM   #16
Nichoms
Nichoms's Avatar
Vehicle: 2002 Mustang GT
From my understanding, learned in several thermo classes, a positive displacement supercharger produces the pressure (boost) inside the case, just as they previously explained, with the air moving down the case in the decreasing space between the rotors, therefore when the air leaves the case it is already pressurized to a set psi. In superchargers that are not positive displacement they just push the air through the supercharger and stack the air ontop of itself in the combustion chamber, or ontop of the intake valve. So the air leaving the supercharger is not pressurized when leaving the case but builds the pressure at the valve simply from the air having nowhere else to go.
__________________
02 GT Saleen supercharged, 30lb injectors, MAC prochamber, flows, Triax, lowered, subframes, 3.73's girdle, rear control arms
317rwhp 335rwtq on crappy lean saleen tune
Now Sniper tuned soon to be dynoed
Nichoms is offline   Reply With Quote
46, allen, cobra, compressor, diagram, displacement, eaton, engineering, ford, m112, mustang, parts, positive, supercharged, supercharger
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
