Go Back   MustangForums.com > Ford Mustang Tech > Pipes, Boost & Juice
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 02-18-2006, 10:10 PM   #1
ByPopularDemand
Default compression and boost
So how do these relate. I know a high compression rate is bad for boost, but how do you know if a turbo or S/C is better
__________________
Quote:
quote:
ORIGINAL: LegallyTorchRED
"Condomless Sex".... is like speeding without a radar detector........ "sooner or later, you're gonna get caught"
ByPopularDemand is offline   Reply With Quote
Old 02-18-2006, 11:10 PM   #2
luckythirteen13
luckythirteen13's Avatar
Vehicle: 92 hatch
Default RE: compression and boost
turbo and sc, doesnt matter when comparing boost pressure with compression. generally, people like an 8.5:1 or 9:1 when they plan to run high boost. although its not uncommon to see people run 8-10psi on a 9.5:1 compression ratio.
__________________
6.90 @ 103.61MPH with a 1.65 60' on low boost-untuned and never been on the dyno
TWIN TURBO!! Keep drooling, I'm spooling
luckythirteen13 is offline   Reply With Quote
Old 02-20-2006, 04:14 PM   #3
ByPopularDemand
So if the ratio is too high nitrous is better? Why is it super chargers are better for stangs
__________________
Old 02-20-2006, 07:20 PM   #4
luckythirteen13
Vehicle: 92 hatch
if the compression is too high, neither forced induction nor n2o is good. you want lower compression for both.
sc are not better for mustangs or really any cars as compared to a sc. turbos are more efficient then a sc and dont produce drag on the crank like a sc does. the reason more people buy a sc is because kits for mustangs are a dime a dozen compared to a turbo kit. most turbo kits are made to order and are very expensive..... usually at least twice the price of a sc. if you can fab your own kit, you can make a turbo kit for a fraction of the price of a sc kit but more people cant make their own turbo set up. i only run a sc because of emissions. the next mustang i build will be old enough to be emissions exempt and will never know what a sc is. it will have a 408 innercooled turbo.
also, because of the ease of installing a sc, the demand is higher then that of a turbo so through competition between manufacturers, the price of a sc kit has come down. then you have the idiots that think turbos are for ricers regardless of the fact that turbos are more efficient and creat more hp per pound of boost then a sc
__________________
Old 02-20-2006, 07:46 PM   #5
FoxRod
Send a message via Yahoo to FoxRod
Quote:
ORIGINAL: ByPopularDemand
Ummm................... you might wanna shoot your sources for telling you that. Cuz they certainly are giving you false advice. I'm not saying turbo's are the best for everyone but it's a fact that a turbo will give you more power than a supercharger at the same psi rating. The reason for that is that it doesn't take power to make power in a turbo unlike in a S/C. It all depends on someones setup as well. Plus people with superchargers are people that want low end torque and don't want to have to wait for the power to kick in whereas a turbo will give you more power but you'll have to deal with the lag. It's a trade off that you have to consider.
__________________
1991 5.0 LX Hatch
F-or
O-nly
R-eal
D-rivers
FoxRod is offline   Reply With Quote
Old 02-24-2006, 06:06 PM   #6
Ultimate Gremlin
superchargers are more ECONOMICALLY sound compared to a turbo....
as far as performance goes...what the guy said above me is dead on...its a trade off
__________________
Do not go where the path may lead. Instead go where there is no path and leave a trail
-RWE
Ultimate Gremlin is offline   Reply With Quote
Old 02-24-2006, 06:28 PM   #7
redass02gt
Moderator
redass02gt's Avatar
the higher the compression rate, the easier (more likely) it is for detonation to occur (gas + air exploding due to heat and compression instead of from a spark plug), which is dangerous for motors.
__________________
RIP tripsevn7
GO BEARS!
redass02gt is offline   Reply With Quote
Old 02-24-2006, 07:04 PM   #8
FoxRod
it breaks down to this. Compression is 5 psi (roughly) is 1 point of compression. So if you are running 8:1 compression and you want to go up to 10:1 you want to run 10 psi of boost. That's how the two are related. Is that what you were askin?
__________________
1991 5.0 LX Hatch
F-or
O-nly
R-eal
D-rivers
boost, compression, high, mustang
Similar Threads
how much nitrous and boost can it hold?? racer02GTstang 4.6L (1996-2004 Modular) Mustang 18 04-05-2007 04:08 AM
compression and boost 7 UP 1 5.0L (1979-1995) Mustang 10 07-03-2006 03:22 PM
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
