Supercharger Engine Life
I'm thinking about getting a Vortech Supercharger System, but I was reading a lot of talk about the life of a Supercharger on stock internals. The Vortech System comes with a lot of extras but I'm sure other things will need to be changed. I plan to change my throttle body andheaders. What other things NEED to be changed to help my engine have a long happy life. Thanx<IMG src=smileys/smiley1.gif border="0"></P>
The System comes with the following:</P>
<LI><FONT face=Arial size=2>Compressor matched, computer aided designed and machined Vortech centrifugal supercharger with SQ technology for "Super Quiet" operation</FONT>
<LI><FONT face=Arial size=2>Calibrated fuel system for proper fuel management<SUP>*</SUP></FONT>
<LI><FONT face=Arial size=2>High performance ignition system with boost timing retard for proper timing curve<SUP>*</SUP></FONT>
<LI><FONT face=Arial size=2>Custom computer tuning<SUP>*</SUP></FONT>
<LI><FONT face=Arial size=2>High flow air intake system with a K&N air filter and specially formed polypropylene plastic inlet ducts for minimum restriction and superior fit</FONT>
<LI><FONT face=Arial size=2>Heat resistant silicone hose coupling</FONT>
<LI><FONT face=Arial size=2>Premium grade flex hose</FONT>
<LI><FONT face=Arial size=2>Stainless steel clamps</FONT></LI>
<LI><FONT face=Arial size=2>Carefully designed and flow tested cast aluminum and/or roto molded urethane air discharge tubing</FONT>
<LI><FONT face=Arial size=2>Compressor bypass valve</FONT>
<LI><FONT face=Arial size=2>OEM style single cast 356 aluminum mounting brackets heat treated to T-6 specifications for strength</FONT>
<LI><FONT face=Arial size=2>Supercharger drive pulley</FONT>
<LI><FONT face=Arial size=2>Integrated belt tensioner</FONT>
<LI><FONT face=Arial size=2>Premium drive belt</FONT>
<LI><FONT face=Arial size=2>Heavy duty mounting hardware</FONT>
<LI><FONT face=Arial size=2>Tie wraps</FONT>
<LI><FONT face=Arial size=2>Heavy duty engine oil lubrication system</FONT>
<LI><FONT face=Arial size=2>Satin or polished finish</FONT>
<LI><FONT face=Arial size=2>Step-by-step, fully illustrated installation manual</FONT>
<LI><FONT face=Arial size=2>3-year limited warranty on most systems</FONT>
<LI><FONT face=Arial size=2>Mandrel bent, TIG welded and powder coated cooling water re-route kit*</FONT></LI>
Yes, 1 day the Cobra will be mine<IMG src=smileys/smiley4.gif border="0"></P><edited><editID>TattooTears</editID><editDate>38027.9380324074</editDate></edited>
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
09-03-2015 07:14 PM
09-01-2015 08:16 PM
