September ROTM nominations
#23
Thanks guys, I accept. Not sure when I should post pics, ROTM section mod keep me up to date, I'll post them in this thread for now. Sorry guys, my pics are way out of date, Selena looks completely different now and doesn't even have the same motor in it, but she probably won't be finished till around Christmas, so I'll post up pics from when and how you knew her best. Maybe for next years ROTM if I make it back in you can get to vote on the revised fully custom Selena.
#24
And my current mod list, just taking a lot of time to get it all in because of how much I work. And here's a semi sneak preview of what's to come.
ENGINE
* Granatelli Cold Air Intake
* SVO GT-40 Ported & Polished Lower Intake
* GT-40 X303 Aluminum Heads w/ Port Matched Exhaust Ports
* 1.70 Crane Cobra Roller Rockers
* Hardened Ford Racing Push Rods
* Removed Smog Pump & Smog System
FUEL, Ignition, & Tuning Components
* 155lb hr Ford Racing Fuel Pump
* Ford Racing 24lb Injectors
* J4J1 Cobra ECU
* Yellow Accel 8mm Spark Plug Wires
* 200 AMP Power Masters Chrome Alternator
* Taylor Distributer Cap
* MSD 6AL Ignition Control Module
* MSD 87-95 6AL Wiring Harness Adaptor
* Crane Fireball Ignition Coil
EXHAUST
* BBK Ceramic Coated Shorty Headers
* Bassini Off Road X Pipe
* Magnaflow Cat Back Exhaust
* MIL Eliminators
DRIVETRAIN
* Steeda Tri Axe Short Shifter
* F1 Racing Stage 3 Clutch
* F1 Racing Chromoly Lightweight Forged Steel Flywheel
* 3.73 Ford Racing Gears
* Ford Racing Aluminum Driveshaft
* Ford Racing 23 Tooth Speedo Gear
SUSPENSION
* H&R Springs 1.5” - 2” Height Drop
* Adjustable Caster Cambers
* BBK Chrome Front Strut Tower Bar
EXTERIOR
* Tinted Headlights
* 96-98 OEM Black Taillights
* Wings West Front Bumper Spoiler
* Saleen Side Skirts
* Saleen Rear Bumper
* Saleen S-281 Wing
* 94-98 Side Scoop Covers
* Cobra Front Bumper Emblem
* Cobra Fender Emblems
* SVT Deck Lid Emblem
* MGW Custom Black License Plate Cover w/ Cobra Insert
WHEELS/BRAKES
* Black 10th Anniversary SVE 17" X 9" Cobra Rims
* 256/40/17 Summuto NT555 Tires
* Black Acorn Lug Nuts
* 10th Anniversary Red Calipers Cobra Brake Conversion Kit
* Custom Zinc Coated, Slotted, Drilled 13" Front Cobra Rotors
* Custom Zinc Coated, Slotted, Drilled 11.5" Rear Cobra Rotors
INTERIOR
* Steeda Compsosite Shifter **** w/ 5.0 Logo
* Satin Door Panel Inserts
* Billet Pedals
* Running Pony Floor Mats
* MGW Satin E Break Handel Cover
* MGW Satin & Black Coat Hangers
* MGW Satin & Black Steering Wheel Turn Signal **** Cover
* MGW Satin Steering Wheel Tilt ****
* Steeda Aluminum Door Handles
* Steeda Satin Switch Buttons
* Running Pony Trunk Lid Carpet
* MGW Satin Door Lock Pins
* Black Carpet Rear Seat Delete
* MGW Satin & Black A/C Control *****
* Satin For Light Switch
* Satin Rear Defroster Button
* Satin Clock Face Cover
* White Face Gauge Cluster
ENGINE BAY DRESS UP
* Chrome Gas Hood Shocks
* Blue Hose Covers
* Chrome MAC Upper/Lower Radiator Hoses
* Steeda Chrome Fuse Box Cover
* Running Pony Chrome Oil Cap Cover
* Windshield Washer Reservoir Cap & Bottle Cover
* Steeda Break Reservoir Cover
* Steeda Power Steering and Reservoir Cover
* Polished Radiator Cover
* Custom Satin Radiator Fluid Overflow Tank
* 94/95 Cobra Black Powder Coated Valve Covers
AUDIO
* Clarion VRX785BT 7" LCD DVD/CD Player, 19 RMS watts @ 4 Ohms, CD Signal-to-Noise 100 dB
* 4 Eclipse SE8375 3 Way Speakers, 5” X 7” 50 RMS watts, 100 Peak Watts, 90 dB Sensitivity
* 2 Boston Acoustics NEO Type M Tweeters, 50 RMS watts, 90 dB Sensitivity
* 4 Gauge Amp Power Cable
* 2 Elemental Designs Dual Voice Coil 4 ohm 10" 11Kv.2 10" Subwoofers, 400 RMS watts, 700 Peak watts, 87.1db Sensitivity
* Hifonics ZXi 2 Channel 6008 Titan Amp, 600 RMS watt @ 4 Ohm Bridged on 1 Channel, Signal-to-Noise 95 bB
* Custom "Made to Fit" Mustang Sub Enclosure
SECURITY
* Viper Alarm System
PAST MODS NO LONGER INSTALLED
* 1.5L Kenne Bell Supercharger
* 55mm 11PSI Pulley
* BBK Cold Air Intake
* Pro M 75mm Mass Air Meter
* Ford Racing 30lb Fuel Injectors
* Nitrous Express Wet Shot N20 Kit
* Performance Products Polished Elbow Adapter
* Auto Meter Gauge Cover w/2 2" Pod Slots
* Phantom 2" Boost/Vacuum Gauge
* Phantom 2" Fuel Pressure Gauge
* 75mm Performance Products Throttle Body
* Saleen S-351 Wing
ENGINE
* J4J1 Cobra ECU
EXHAUST
* MIL Eliminators
DRIVETRAIN
SUSPENSION
EXTERIOR
* Tinted Headlights
* Saleen S-281 Wing
WHEELS/BRAKES
INTERIOR
* Billet Pedals
ENGINE BAY DRESS UP
* Blue Hose Covers
AUDIO
SECURITY
* 55mm 11PSI Pulley
* Saleen S-351 Wing
#25
What we do is have nominations, then once I have 5 I get at least 1 picture from each nominee. Then I will make a thread once September arrives, and post those pictures there. After the thread is up you guys/gals can post up pictures like crazy.
