Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Appearance Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-22-2009, 09:10 PM   #21
2008moosetang
I got my here, http://www.meter4it.com/ I really like having the option of chase or seq. I had a previous kit that just had the sequential and since I installed the kit its been on Chase and no complaints. The kit is a little more time consuming then a plug and play but not to much work.
__________________
2008 Black Mustang GT Premium Package, Full Blown Exhaust Mufflers, Sequential Chase Tail Lights, Cervini's Ducktail Fin Spoiler. Work in progress...
2008moosetang is offline   Reply With Quote
Old 09-22-2009, 11:31 PM   #22
charliebrown266
charliebrown266's Avatar
I have the cdc,work great,simple install!
__________________
08' GT ALLOY, MGW, Roush Suspension, roush body kit, Magnaflow Magnapack Cat back, Mtx Sub Encloser.C&L racer,93 brenspeed tune,20" TSW wheels,AVIC-D3
charliebrown266 is offline   Reply With Quote
Old 09-23-2009, 10:09 AM   #23
flash_xx
Vehicle: 2007 Ford Mustang GT
WebElectric here, I got the one that comes with the OEM harness so no cutting or splicing involved.
__________________
flash_xx is offline   Reply With Quote
Old 09-24-2009, 01:53 PM   #24
Centurion96
Centurion96's Avatar
Quote:
Originally Posted by Elcameeeno View Post
What is the lone green wire used for on each side? (Picture on the AM site) It looks like it needs to be crimped to something...
I'll make a guess that it's a trigger wire. On my Webelectric install I used his instructions on how to apply the sequencing only when the turn indicators were employed. It required cutting the green trigger wires (which were spliced to the rear lamp hot wires) and splicing these to the front turn indicator wires at the junction box, making sure that left was to left and right was to right. As a result, my lamps do not sequence when I depress the brake pedal.
BB
Semper Fi
__________________
07 GT vert, IUP, Comfort group, 3.55LS, manual, side airbags, Torch red with cloth top.
Centurion96 is offline   Reply With Quote
Old 09-25-2009, 04:44 PM   #25
southernmustangparts
Former Sponsor
Quote:
We have a bunch of sets of the WebElectric Sequentials here at the shop
$119 w/ Free Shipping
WebElectic Sequentials
Thanks
Ken
southernmustangparts is offline   Reply With Quote
Old 09-27-2009, 12:34 PM   #26
graygt07
Vehicle: 07 ford mustang
i want one that will flash multiple times not just once. Which ones do, i saw one but i cant remember if it was on the 2010 mustang or an older one.
__________________
07 auto with brenspeed stage 3 saleen 420rwhp/405
1.82 60' 1/8 7.65@93 1/4 11.90@115.5 on stock tires no susp. mods YET
UPDATE: stage 4 with saleen supershaker 454hp/439tq NEW PERSONAL BEST may 1, 2009 cordova il. 11.25@121.65 with 60' 1.649 on hoosier drs and all else stock.
graygt07 is offline   Reply With Quote
Old 09-27-2009, 03:58 PM   #27
Centurion96
Quote:
All sequentials have an electronic module which is triggered by a change in voltage on a sensing or trigger wire. From the manufacturers these sensing wires are usually attached to the input voltage line for the lamps. This means that when the turn indicator module or PCM (in 2007s and up) flashes the turn signal, the lights sequence and will continue to sequence each time the flash voltage is sent to the bulbs. Where you are hearing the sequence once event is when you hit the brakes. This is because the rear turn signals share the same wire as the rear brakes.
Now to avoid the single cycle of the sequencing when you depress the brakes you need to disconnect the sensing or trigger wire from the rear lamp power wire and connect the appropriate trigger wire to the front turn signal lamp hot wires. Then the sequencing module will only flash each time your front turn signal flashes. When you hit the brakes, they will not sequence.
BB
Semper Fi
__________________
Old 09-27-2009, 09:02 PM   #28
Elcameeeno
I just installed the set I got from AM. So easy a caveman could do it!
Elcameeeno is offline   Reply With Quote
Old 09-28-2009, 12:12 AM   #29
whtnblk.GT
Vehicle: '07 Performance White Mustang GT Premium
Arrow
Can you put up a video of your kit from am? I wonder how good their kit is...
__________________
Wish List:
-ProCharger HO Intercooled Tuner
Supercharger Kit With
800+ HP Intercooler upgrade
"Wars come and go, but my soldiers stay eternal."
whtnblk.GT is offline   Reply With Quote
Old 09-28-2009, 09:30 AM   #30
Elcameeeno
I don't have any video capabilty, but basically you pull the center trim piece, unbolt the tail light housings, swap out the harnesses and bulbs and put it back together. Took about twenty minutes start to finish. The turn signals flash center ->outwards. And the brake lights sequence once center out when the brake pedal is depressed. The kit is a direct replacement and the quality appears to be at least equal to OEM.
2009, buy, canada, cars, forums, gt, ho, light, lights, mustang, sequential, sequential tail lights, slot, tail, virginia
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
