I'm going to get the Eibach Pro-System (part # 35100.780). Copied from the product page:
Pro-System; Lowering Kit; Incl. Pro-Kit High Performance Coil Springs/Pro-Dampers Performance Shocks; Front w/1.3 in. Drop; Rear w/1.4 in. Drop; Features:
Excellent Performance: Low Look Superior Cornering.
Surprisingly Smooth Ride Quality.
Precision Engineered Suspension System - balanced combination of dampers, Pro-Kit springs and bump-stops (secondary springs).
No Guesswork: Install, Set the Alignment and Drive.
Now...my question: How do you align it? Does it come with what I need or do I need to buy something seperate? I found this:
Eibach Springs Alignment Kit
Ford Mustang Alignment Kit
Part#:5.81260K
Fits: 2006 to 2006 Ford Mustang
Brand: Eibach Springs
Notes: Pro-Alignment Camber Kit; Front +/-1.5
to align you car , lol you must go to a garage with an alignment machine but to do anything your going to have to order eibachs camber kit for the 05 -06 mustang.. because essentially when you lower the car your front tires lean inwards giving you negative camber.. which will eat your tires.. the positive side to negative camber is that your car will handle even better than if you put the camber kit on... but handling improvement over stock is huge anyways
__________________
05 V6 black,std, red int
alpine CD9835
10" rockford P2
directedaudio x2600 amp
xenon rear window scoops
eibach pro-kit
Dual GT take offs
with the prosystem.. basically you wont have to disassemble your stock struts.. the aftermarket shocks should come with its own hardware.. so pretty much put it together and install on your car..
__________________
alpine CD9835
10" rockford P2
eibach pro-kit
Dual GT take offs
ORIGINAL: blackfoot
Oh ok so I can install the Pro-System myself then go to a shop and have my car aligned using the camber kit? Or is the camber kit an extra thing that I have to do?
