Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-05-2006, 01:16 AM   #1
pony girl 05
Default tire pressure question
This has probably been asked before but hopefully you guys can help me out. I have 17 in Pirellis on my car, the tire says max inflation is 51 lbs, the sticker on the inside of the car door says 60 lbs What do you guys run with your cars?
__________________
pony girl 05 is offline   Reply With Quote
Old 09-05-2006, 01:26 AM   #2
davelong667
I ♥ Acer
Default RE: tire pressure question
I run 32-35 all around, decent traction, decent gas mileage, decent ride. If you ran 51 or even 60 psi youd probably have a car that rode like it had concrete wheels...lol Not only that, your traction would SUCK. Also, your tire wear would not be good. Too much pressure and youll wear the center of the tire down faster than the edges. Too little pressure and youll wear the edges faster than the center, thus giving uneven wear.
davelong667 is offline   Reply With Quote
Old 09-05-2006, 01:31 AM   #3
steve_stang
35 on the fronts and a little harder on the rears 37 or so.
__________________
Steve
2005 V6 red fire 4.0, Manual, Shaker 500, IUP
Superchips, K&N Airchager CAI, Flowmaster axle-back AT, Hurst Pro Comp Shifter, Tint, SilverHorse Honeycomb Rear Panel, 18" Fast - Blade rims and BF Goodrich G-Force KDW's T/A NT - 245/45ZR18
steve_stang is offline   Reply With Quote
Old 09-05-2006, 02:12 AM   #4
ricklmesa@cox.net
I like 35 in the back and about 37-38 in the front.
__________________
Procharger
298whp 299wtq @7 psi wintertune
301whp 300 wtq @9-10 psi summertune
JBA Exhaust (X pipe)
JBA Headers
ADC Custom Tune
Steeda Shifter
CHE LCA's, UCA
CHE K-member Brace(to be installed)
3:73's & tlok
PH Driveshaft
ricklmesa@cox.net is offline   Reply With Quote
Old 09-05-2006, 02:14 AM   #5
randy78045
i run 15 lbs in my slicks... [:-]
__________________
[color=blue]
’88 GT Hatchback
408 Stroker / AFR Heads / Demon Carburetion
430 RWHP ***** 426 FT/LBS ***** ET: You Pay, I'll Play [8D]
Daily Driver
[center]
randy78045 is offline   Reply With Quote
Old 09-05-2006, 08:44 AM   #6
Vehicle: 2006 Ford Mustang Pony Vert
Quote:
ORIGINAL: pony girl 05
Pony girl -- take a look at your door sticker again, 60 sounds very high and out of the ordinary for the recommended tire pressure.
__________________
Xcharger #020, J&M LCA/UCA; 8.8/3.55 & LPW cover; Dual GT500 take offs. Black bullitts. Shaftmaster aluminum DS. PB: 13.60 @ 100+ juiced - Xcharger: 13.42 @ 101
JimC is offline   Reply With Quote
gforce, goodrich, kdws, mustang, pressure, recommended, ta, tire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
