Once you get going on the suspension, it will be hard to stop until all the core components are replaced with Steeda, Spohn or BMR stuff. Nice thing is you can do this piece by piece and build it up over time but the big bang approach of doing it all at once works too!
__________________
2007 Mustang GT/CS coupe, 5 spd C&L Intake, Steeda UDP's, Brenspeed tune,Violator axle back, off rd H pipe,Hurst shifter, Steeda steel LCA's, Steeda Sport Springs, Tokico D-Spec's, Spohn F&R sway bar's, BMR panhard bar, Spohn UCA, GT-500 rear spoiler.
Yeah, the suspension mods can get addictive. It's tempting to just go in there and replace EVERYTHING.
Of course, you have to draw the line somewhere.
I think that for the average street-driven car, the UCA and the panhard brace are in the "optional" category. If you can afford them, get them. If money is tight, skip 'em.
On the other hand, if you are building up for racing or forced induction, then I would say get them for sure. Androz, you said you're getting a turbo, right? If that's the case I would definatley get both the panhard brace and the UCA. Also get the poly bushing that goes in the diff housing, and I would also seriously consider the UCA mount as well.
__________________
Black 2006 GT Coupe
Dynatech LT headers & X; Borla catback
C&L CAI; 93 oct tune
Full BMR, Spohn & Steeda suspension
D-Specs; Alum driveshaft
Second Skin Audio damping; Infinity spkrs;
Goodyear Eagle F1 255F/295R - FR500 wheels
Hey crazyal do you recommend UDP? I got a around 100$ over in refund from rpmoutlet and think I might get their UDP's. Do you think I should get it or the panhard brace they sell? Has 2 be one of the two since I have most of what they can sell. Only other thing I have been thinking about is the mezierre water pump. How much does the alum driveshaft goes for? If it like 100$ more than the waterpump is it a better mod to do? Also I read that the panhard brace is for the one with rod ends. I got the adjustable one with the polyurethane bushings.
I'm going to send you a PM regarding the UDP/pump so this thread doesn't go off topic
The panhard bar brace (or support if you want to call it that) has nothing to do with rod-ends or otherwise. It will work just fine with your poly-bushing panhard bar.
I would buy the BMR panhard brace. RPM Outlet has it for 99.95.
__________________
Black 2006 GT Coupe
