2007 Pony Package??
#21
RE: 2007 Pony Package??
ORIGINAL: chrisc
everybody will have sway bars, even the very very very very basic 6ers. the 06 pony package gave you the GT rear sawy bar, while the 07 pony package does not. however, you will still have sway bars in your car
that is for sure, ask your for dealer and they will confirm it
#22
ORIGINAL: chrisc
#24
2007 Pony Package
"For V-6 buyers, the Pony Package includes a customized grille with GT-style round fog lamps and a chrome bezel, or “corral,†around the traditional Mustang prancing horse. Backing up this visual upgrade is a GT-inspired suspension featuring a larger front stabilizer bar, the addition of a rear stabilizer bar and P235/55ZR17 tires on painted cast-aluminum wheels. With bright machined rims and unique tri-bar Pony center caps, these are the largest factory wheels and tires ever fitted to a V-6 Mustang."
"Further touches include Pony front fender badges, lower door tape stripe, carpeted front floor mats with special brushed chrome “Mustang†logos and a rear spoiler. "
http://media.ford.com/products/press...amp;make_id=92
Cheers
Cheers
#25
the 07 pony package and the 06 are different. also, in 05 there was no pony package. furthermore, pony package is not the same as "delux" or "premium" car.
I am only talking about 06 pony packages.
Furthermore, when I got my exhaust installed, I indeed had both sways
#28
Every PP I crawled under in 07 when I bought mine had a
31.5mm front sway and a 18mm rear sway bar.
And I was under hundred of them new on the lot.
The 2007 mustang specs also confirm this.
Its not listed on the window sticker.
But crawl underneath and there they are.
I know the 2007 model year well.
As well as the 05, 06, 08, and 09 model years.
BTW, the white endlinks denotes a Vert sway bar
and the black endlinks are for a Coupe. V6 or GT.
I have personally observed this and read it in the
Ford Workshop manual. Its a clearance thing for
the Vert top and Vert undercar bracing that Coupes
dont have.
I sure would like to have the Vert bracing under my Coupe.
That would be a nice cheap mod to stiffen the chassis on a Coupe.
#29
[QUOTE=157dB;8071205]
The white end links means it's a vert sway bar? Are the convertible bars stiffer? Because I have white endlinks on my rear sway bar, and it's a coupe... Hmm, previous owner might have done some mods after all =D
This statement is so wrong in so many ways my head is spinning.
dont have.
dont have.
#30
Nope, not stiffer.
Just indicating that the bends in it will clear the
Verts undercarrage that is different than a Coupe.
The mid point attachments at the body are different.
Causing a binding at full rear end suspension travel.
All is good sitting still at ride height but hit a bump
and land on the suspension jounce bumper or extend
the shocks completely and watch out Nelly.
Its kinds like how the 05-09 Mustangs M/T and an Automatic
mufflers are different internally but not apparent to the untrained eye.
