RE: Max tire width?
The widest tire you should run on an 18 X 8.5 is a 255. 255/45/18 is the correct plus size. You canmount a 275/40/18 on an 18 X 8.5 and drive on it, but the performace characteristics of the tire are impaired. I am running 255/45/18's on the stock 18X 8.5's along with suspension significantly modified for street / road race applications (see sig below) with very good results.
[IMG]local://upfiles/63299/DBC61AA169224990AA1D5A34F80F1D2C.jpg[/IMG]
__________________
07 GT M5, Eibach pro kit, FRPP dampers, Steeda [F/sway bar w/braces, R/sway bar w/links, Adj STB, Adj PB, HD PB brace, UCA, CAI, HF inlet, CMCV's, UDP's], CHE K-Brace w/TLMs, BMR LCA's & LCA Relo brkts, FRPP 4.10's, 255/45/18's, Hawk, 311 RWHP, 328 RWTQ
