Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-26-2007, 03:09 AM   #21
PowerHitter
Default RE: Complete Suspension Overhaul
DocVenture:
I have almost the exact same suspension that F1Fan has recommended for you. You are really going to like it.
Manufacturer Description Part #
Eibach Springs - Pro Kit Mustant GT 35101.140
Ford Racing Mustang GT Damper Kit M18000A
Steeda Mustang - Adj Strut Tower Brace 555-2752
Steeda Mustang - G-Track Brace 555-5530
Steeda Mustang - Adj Front Sway Bar 1-3/8 555-1050
Steeda Mustang - Front Swaybar Mount Brace 555-5553
Steeda Mustang - Rear Sway Bar w/links 555-1052
Steeda Mustang - Adjustable Panhard Bar 555-2551
Steeda Mustang - Panhard Bar Brace 555-2555
Steeda Mustang - Adj Lower Trailing Arms 555-4416
Steeda Mustang - Tublar Upper 3rd Link 555-4105
BMR Bolt in Relocation Brackets CBA005
Hawk HP Plus Front Pads 164-HB484N.670
Hawk HP Plus Rear Pads 164-HB485N.656
Goodyear Eagle F1 GS-D3 VBS 255/45ZR18
Pic of one of the sway bar mounts on my car
[IMG]local://upfiles/71338/EAA0286AFF37451DACD266941CD6E178.jpg[/IMG]
__________________
07 GT M5, Eibach pro kit, FRPP dampers, Steeda [F/R A-R bars, A-R Brace, Adj STB, G-Trac, Adj PB, HD PB brace, Adj LCA's, UCA, CAI, SCT, HF inlet, CMCV delete, UDP's], BMR LCA Reloc, FRPP 4.10's, 255/45/18's, Hawk, 311 RWHP, 328 RWTQ, Kicker amp/dual 10s
PowerHitter is offline   Reply With Quote
Old 07-26-2007, 04:56 AM   #22
mygt500
Multi-Tasking Moderator!
mygt500's Avatar
Vehicle: 2006 Ford Mustang GT
Do a search for CrazyAl and he has a wealth of info as well....F1Fan 's info is great as well.
__________________
2006 Mustang GT with Cervinis Kit
Whipple Crew member
H.O. S/C 465 RWHP and 440RWTQ
First online article about my car! check it out!
http://www.examiner.com/examiner/x-8811-Detroit-Sports-Car-Examiner~y2009m5d30-Jason-McGuires-2006-Mustang-GT
http://www.cardomain.com/ride/3342086
www.mocsem.com
mygt500 is offline   Reply With Quote
Old 07-26-2007, 10:21 AM   #23
TPony
TPony's Avatar
Vehicle: 2006 GT Vert
this thread definitely going in my goodies folder....thanks!
__________________
Roush Fascia/chin/scoop, DD 18X9 w/NT555 255/45/18, GTA Axlebacks, GT500 spoiler/pedals. Many interior billet upgrades, sequentials, engine dress up, chrm valve cvrs, Steeda LCA, GMS CAI SCT X3, Brenspeed 87.
TPony is offline   Reply With Quote
Old 07-27-2007, 12:54 PM   #24
DocVenture
Hey Power Hitter how do you like the Goodyears? I haven't even started looking at tires yet.
DocVenture is offline   Reply With Quote
Old 07-27-2007, 01:48 PM   #25
F1Fan
Vehicle: 2005 Ford Mustang GT
Quote:
ORIGINAL: RodeoFlyer
.......got alignment plates and a bumpsteer guage?
Hi RodeoFlyer,
Never had a set of turntables of my ownbut I used to use a toe gauge I made up out of a scrap piece of 2" aluminum box tubingwith somesteel rods attached to a couple of short sections of slightly larger box tubing (with thumbscrews to lock them in place),acting as a slider to measure toe on a chalk line I put on each tire. These daysI just take the car to Marlo's of if I have to I'lluse a tape measure and an attachment ona portable camber gauge I borrow fromafriend of mine.
Cheers!
__________________
2005 Mineral Grey Mustang GT Coupe, Premium, M5, ICAP, IUP, Active Anti-theft, LoJack
Mods: Gave up trying to make it all fit, but ask if interested!
F1Fan is offline   Reply With Quote
Old 07-27-2007, 02:14 PM   #26
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
I guess that's better than a roll of string, framing square, tape measure, and torpedo level. oh and beer lol
__________________
Thanks to Wild Pony Motorsports, Ross Murray, and Agent 47.
RodeoFlyer is offline   Reply With Quote
Old 07-27-2007, 05:48 PM   #27
F1Fan
Hi RodeoFlyer,
LOL! I like used to roll the front tiresto put chalk lines on them. Then I used a piece of 3-5# monofilament flyfishingleader with a 13mm nut on one end to act as a plumb bob and apush pin tied to it with a small washer under the headto control the depth and stuck it into the tire on the chalk line of each tire front and back. Then I just had someone help me reada steel tape and I could get a good toe measurement by reading the front and then the rear measurements off the tape. It was pretty close. the only real advantage to my homemadetoe gauge was that I could take a toe measurement solo. The fancycamber gauge attachments work O.K. too but re obviously not as cheap as my homemade setups. The small leader withjunk nutplumb bobs was the cheapest and simplist way to get a reliable toe measurement I ever came up with that actuallyworked.
Cheers!
__________________
Old 07-28-2007, 02:40 AM   #28
dseid2
DocVenture:
PowerHitter here. The dseid2account I am on nowwent down for about a month, so I created PowerHitter till the powers to be got my dseid2 account back up. Anyway, to answer your question, I really like these tires. I used to run them on my old BMW 528 too. They have good performance, a reasonable price and a tread design seems to be very good in both wet and dry conditions.
Have you thought about your brakes yet? If not I would recommend Hawk HP Plus pads. They are noisy and dusty, but what an improvementin stopping power and reduced fade. I was ready to upgrade to 14 inch rotors and 4 piston calipers, before I tried these pads. I am glad I triedthe Hawksfirst. It is not a full race set-up, but the Hawk HP Plus pads are a good choice for a street/occasional track application.
Best Regards
__________________
07 GT M5, Eibach pro kit, FRPP dampers, Steeda [F/sway bar w/braces, R/sway bar w/links, Adj STB, Adj PB, HD PB brace, UCA, CAI, HF inlet, CMCV's, UDP's], CHE K-Brace w/TLMs, BMR LCA's & LCA Relo brkts, FRPP 4.10's, 255/45/18's, Hawk, 311 RWHP, 328 RWTQ
dseid2 is offline   Reply With Quote
Old 07-30-2007, 09:33 AM   #29
DocVenture
I've looked at brakes a little. Most of the set ups I've seen are way to much. I'll check out those pads, and mabe some slotted rotors.
Old 09-25-2007, 11:56 PM   #30
DocVenture
Any advice on how to arrange the spacers on the bumpsteer? Went with Eibach Pro Kit springs and Spec D shocks.
25545x18, 5552551, 5555553, 5558113, duty, heavy, mounts, nvh, site, specs, steeda, steedacom, strut, tire, upper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
