GT 500 SWAY BAR ON A 07 GT
Old 07-19-2007, 04:54 PM
sd07gt
sd07gt's Avatar
Default GT 500 SWAY BAR ON A 07 GT
Do I need to buy the gt 500 rear bushings or can I use the stock ones off my 2007 gt..... ( there are two at the end of the bar and two at the center of the bar) when installing the rear sway bar off a GT 500
Thanks
sd07gt is offline
Old 07-19-2007, 05:41 PM
F1Fan
F1Fan's Avatar
Default RE: GT 500 SWAY BAR ON A 07 GT
ORIGINAL: sd07gt
Thanks
Hi sd07gt,
Yes. The bar is larger in diam. so the bushings need a larger opening to work smoothly and to thread over the bar if you are reusing the stock links.
Cheers!
F1Fan is offline
flash_xx
10-16-2015 07:23 AM
UrS4
10-03-2015 06:23 AM
fastbackford351
10-01-2015 12:24 PM
winner99
10-01-2015 10:52 AM
nmra1965
Other Professional Racing
09-26-2015 10:46 AM
Quick Reply: GT 500 SWAY BAR ON A 07 GT
