Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-19-2007, 04:44 PM   #1
v8pilot
Default 315x35x17 wheels and tires
So I what I want to do is get 315x35x17 in the rear and 275x45x17 in the front and tires. for tires i want to do nitto 555r. but i dont know what rims i want yet. i was thinking either bullits or fr500. does anyone know where i can find a lighter set of rims that the dimensions i drescribed. or any rims that big online for that mater
__________________
-07 JLT II & XCalib 2 O/R-H pipe, Steeda swaybar
Steeda Adj LCA, LCA Relo bracket H&R RS, D-spec, 4.10 adj panhard, Hurst ssk 60ft-1.9 - 1/8th-8.6
v8pilot is offline   Reply With Quote
Old 09-20-2007, 01:52 AM   #2
F1Fan
Vehicle: 2005 Ford Mustang GT
Default RE: 315x35x17 wheels and tires
Quote:
ORIGINAL: v8pilot
Hi v8piolt,
Your car will look stupid with these wheels and tires on it and they will messup the suspension geometry. There are basically only two sizes that will work for the S1987GTwith a 17"wheel, a 235/55x17 or a 255/50x17 on a 17"x8" or 17"x9" wheel. The reason is the tire height needs to be 27" tall give or take 0.2" or so or the car looks goofy and the computer will be mixed up.
If you want to go wider you need to go to an 18" or larger wheel. In 18" wheels there are many tires that you can use but the most common 18" sizes are 255/45x18,275/40x18and 285/40x18 on 9"-10" wide wheels.
HTH!
__________________
2005 Mineral Grey Mustang GT Coupe, Premium, M5, ICAP, IUP, Active Anti-theft, LoJack
Mods: Gave up trying to make it all fit, but ask if interested!
F1Fan is offline   Reply With Quote
Old 09-20-2007, 10:34 PM   #3
Poco
Poco's Avatar
I runa 295/45/18-18x10's on the rear and the speedo is acurate.I thought it would be off but even the dealership checked out and said it was good.
__________________
07'GT Grabber Orange-"Tang"
Poco is offline   Reply With Quote
Old 09-20-2007, 11:13 PM   #4
F1Fan
Quote:
ORIGINAL: Poco
Hi Poco,
Unless you have a hand held tuner or your car was dyno tuned and the tunercorrected fortire revolutions your speedo isoff and your dealer isnot very particular. A 295/45x18 turns 734 times per mile and the stock 27 tall ties ture 770 times per mile. Based on this set of facts your speedo is off at least 5%possibly more depending on what wheels the car was shipped with. What is an Nitto E-555 tire?
HTH!
__________________
Old 09-20-2007, 11:26 PM   #5
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
Quote:
ORIGINAL: v8pilot
PUSH PUSH PUSH PUSH PUSH PUSH PUSH PUSH PUSH
no prob - i'll give it more gas..........
aww crap now the ass is coming around!!!!!!!!
oops! over-corrected!!!! now we're going all the way around!!!!
Waaaahh....waaaaahhhh.......waaaaaaaaaahh
PUSH PUSH PUSH PUSH PUSH PUSH PUSH PUSH, etc etc etc
LOL
that's what you can expect on those tires
__________________
Thanks to Wild Pony Motorsports, Ross Murray, and Agent 47.
RodeoFlyer is offline   Reply With Quote
Old 09-21-2007, 01:48 AM   #6
v8pilot
what tires would you recommend then?
__________________
Old 09-21-2007, 01:46 PM   #7
F1Fan
Quote:
ORIGINAL: v8pilot
Hi v8pilot,
To do what task? For a N/Astreet car with a cornering focus and damn the ride? 255/45x18 or 285/40x18 tires on 18"x9.0-9.5" rims with the right offset that allows the wheels to stay inside the wheel wells. I've always prefered a car with a little bit less wide tire than migh be considered optimum for the power of the car so you can use throttle a bit more liberally to make the car turn. I've run the stockwheels and tires while optimizing and playing with the various suspension options out there and you can have a VERY funt to drive car that rides well on 17" or 18" wheels and tires.Currently I'm running275/40x18 BFG g-Force KD's all aroundand while the grip level differences arehuge thestickier tiresare really not as much fun to drive on as the skinnier tires. I'm torn between the fun of skinny tires and the pure brutalgripof the wider tires. But if you are after pure grip the ideal size is a 285/40x18 on a18"x10" wheel IF you can find the offset that meetsyour needs as outlinedbelow. The problem is that there are very fewhigh grip tires in this sizebut plenty of 275/40x18's which are 0.1"-0.2" or slightly shorter than the ideal 27"+ tall tires. The best of the dryperformance tiresin a size thatis appropriate for the car in a 275/40x18 are BFG g-Force T/A KD, GoodyearGS D3,Bridgestone RE050A Pole Position, Michelin PilotSport 2, Dunlop Sport Maxx.
Anywheels you chooseshould have enough offset and aspoke designedto clear a BBK (Big Brake Kit), if you have ANY thoughof installing a BBK down the road. Also if you are looking at keeping your frontalignment aggressiveon a set of Sportsprings that do not lower the car more than an inch you need to be sure that the inside wheel and sidewalls will stay clear of a strut that is modified with Steeda's billet strut camber plate system or you will not be able to crank in enough negative camber to keep the front tires happy while goingaroundcorners. A set of Eibach/SPC camber bolts even with Steeda HDCamber Adjustable Strut BearingMounts are not enough to get you where you want to go so you have to keep the clearance in mind if cornering is your thing.
HTH!
__________________
27, 275x45x17, 285, 2954518, 315x35x17, 40x18, aspoke, bfg, dimensions, kd, michelin, rims, ta, tall, tire, tires, wide
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
