CHE Torque Limiters
CHE Torque Limiters
I just bought the che bar with torque limiters and was wondering if this will void any of my warranty? I only have 6000 miles left on my warranty and it will be installed by my Fiances boss. Also does anyone have any instructions on installing LCA's, Panhard bar, UCA, and if I need a different size bolt for the UCA? I tried the search function but as we know it is not fixed yet.
RE: CHE Torque Limiters
Do a page x page search backward and will find MANY posts on UCA, LCA, pan-hard installs bolts and such. This has all been covered multiple occasions. As for the CHE bar, isn't that the one that helps avoid the binding of trans when under load and shifting to third on the S197's? If so, removing the necessary bolts from chassis to install it will possibly do just that. If I were you, I would ask a Ford dealer as to this issue, but probably do iteither way. If you don't want to do that, have a Ford dealer install it. It will certainly cost more to do so, but could address and probably resolve any warranty issues going that route.
I have read the entire Ford warranty program and specifically states that 'no Ford vehicle warranty work will berecognized by a fiancesboss'
Jazzer
Jazzer
Try a Google search, adding
site:www.mustangforums.com
at the end of your search terms.
Also, check out Taco Bill´s write-ups and the S197 TECH (stickied threads at the top of the main 2005 - 2008 Mustangs forum).
Norm
Norm
The instructions are on CHE's web site. See link below. Once you put this in there is no need to upgrade the shifter or to go with solid motor mounts. No more missed shifts.
http://www.cheperformance.com/instru...1DE_Print.html
treesloth
09-28-2015 07:03 AM
LivingInThePast
09-16-2015 12:20 PM
