How much brake fluid to flush system?
I used about 1 1/4 - 1 1/2 when I did a flush, guess I pumped the brakes a little more than Sleeper did. Purchasing two liters turned out to be a wise decision because, after each track event, I bleed each brake about 5 pumps (theory being to get rid of the fluid nearest the caliper after the intense heat of a track day). So having the extra has served me well.
I reverse bleed, and by doing that there's always a chance you might have to do one corner more than once, so I always buy two quarts just in case. If you're replacing calipers you'll need to have two on hand for sure. It's easier to have more than you need than make a run to the parts store in the middle of the job.
LivingInThePast
09-16-2015 12:20 PM
09-08-2015 11:50 AM
