Reducing understeer
Reducing understeer
Just got back from TWS and my instructor suggested that I try left foot braking since I'm comfortable with it in my auto transmission daily driver.
Wow, all my complaints about a lag during turn in are gone. Applying throttle while releasing the brakes or using the brakes with part throttle really calms the car down.
Unfortunately just a little too much throttle gets me into serious understeer at mid-corner and track out.
So my question is, how can I reduce understeer without reducing rear, or more correctly, total grip?
- I already have CC plates.
- I could use wider front tires - no.
- I don't think that I could add a low enough front splitter to make a difference.
- Taking weight out of the front of the car is very very expensive.
It seems like sway bars are the only option. But don't sways just reduce understeer by throwing away rear grip? Or is that not such a bad thing on our front heavy cars?
The real question is, will tuning with sways have an overall effect of making the car faster?
A pro that helps me out has "never bought an aftermarket swaybar in my life".
The lack of camber seems to be a common complaint about the MM plates. With my KW setup I can get over 3.5
What is your toe set at? Can you afford to toe it out some?
You can drill your own holes in the factory front bar and free it up some. If you don't have a set of adjustable end links yet I would get a set of Strano's and at least get rid of the pre-load.
Have you played with your shocks? Soften the fronts and/or stiffen the rear.
Have you kept a log of your tire temps and pressures? Go up in the front and/or down in the rear if you can.
How much fuel are you running? When I started out I just thought the track got hotter as the day went on (it does), but then I realized DUH - by the later sessions I had burned off 100lbs of ballast in the rear. Toss your spare and jack back in too if need be.
The rule of thumb is to address the misbehaving end. Make all of the adjustments you can in the front. If it still pushes too much make adjustments in the rear.
The end links help a lot also. I have has a handful of people autocross my car after I installed Strano's end links and they were all amazed at how well the car turns in.
what kind of event did you do? i'm thinking about doing one of the Driver's Edge events there next month. just did my first autox in over a year and it made me really want to do events more often.
Both the TWS Motorsports Club and The Driver's Edge have events there. The Driver's Edge events fill up pretty quickly, especially for the Green or beginner's group, however I think that the Motorsports Club has gotten pretty close in terms of professionalism.
I do mostly Motorsports Club events because they let me do Saturday only, which works for my schedule a little better.
Hello, we offer a solid 7/8" rear sway bar. The bar also has new urethane bushings and billet end links. We also have the extreme anti roll bar which is intended for reducing body roll for drag racing applications. If you have any questions about our products please give us a call.
http://www.bmrfabrication.com/2005Mustang.htm
I'd try a set of Vogtland springs and leave the sway bars alone, while making the shock adjustments noted above (rear firmer, front softer). Of course, YMMV.
But why not just call Sam Strano and ask him? He can set you up with what you need.
www.stranoparts.com
www.stranoparts.com
