Brake System Flush
Brake System Flush
So, I picked up some ATE Super Blue earlier today and am hoping to put it in this weekend. Right now I'm planning on just bleeding my brakes like normal a few times, but replacing the discharged fluid with the ATE. It can mix with my current fluid, right? Does anyone have any better suggestions on how to do this?
Also, is there a specific pattern we are supposed to bleed? Last time I bled, I did RR, RL, FR, FL.
Any input is appreciated, I'm new to all of this brake work, but want to get proficient at it.
When we did mine we drained as much of the old fluid out of the reservoir as possible before adding the ATE Super Blue. Then kept bleeding the wheels one by one until the fluid came out blue.
Good luck.
Good luck.
Same here. With the speed bleeders its pretty easy. I used a turkey baster to get as much out of the MC as possible, then topped it up with super blue and pumped away. Your rotation is correct. This isn't the perfect way to do it but its good enough. You still will have old fluid in the abs and clutch.
I took mine to a local shop the first time I switched over to the new fluid. They had the right device to cycle the ABS and fully flush it of the old fluid. After that, I just do flushes the normal way.
I've heard that you can effectively clear the ABS unit by doing some heavy braking to get the unit to discharge. I don't know the specifics of this procedure (how many times you need to activate the ABS), but I do know that until you activate it either this way or through the shop device you'll always have that old fluid in the ABS. Flushing the fluid alone will not clear the ABS.
Best,
-j
Best,
-j
Start with the wheel farthest from the master cylinder and work towards it (passenger side rear, driver side rear, passenger side front, driver side front). Bleed until you see dark blue (no air) the move to the next wheel. Don’t forget to keep an eye on the reservoir. I usually use about a liter and a half when I change the fluid, which may be more than necessary but I’d rather be safe than sorry.
Hi Robertj,
I had the system flushed along with a few other things done at the same time. I think I got "a deal" on the package (pads, braided brake lines, system flush) so I don't really recall the price for cycling the ABS itself.
I could dig up some receipts, but I seem to recall it wasn't much (or at least I felt it was well worth it). Sorry I couldn't be more more specific.
Best,
-j
Best,
-j
