Steeda Pro Action Shocks
Old 03-30-2017, 07:06 AM
Norm Peterson
Norm Peterson's Avatar
About four years in, my yellows looked like this ↓↓↓
That included four winters (NJ), two of which were where the Mustang was my daily commuter. They didn't look much different two years later when I swapped the OE springs out for something a bit stiffer but not much lower.
It's definitely a matter of individual perspective. After 9 years and counting, I still haven't even touched the OE exhaust system on my '08 (though there is an FRPP cut/clamp X-pipe going on once the weather gets a little nicer).
edwgrafe - depending on what you're running for springs, Koni yellows can be adjusted to feel anywhere from too soft for performance use up to way too firm for comfort on expansion-jointed roads. Picking and/or adjusting shocks should be more for providing vehicle behavior that's composed for the driving that you do rather than to hit some vague stiffness target.
Norm
Norm Peterson is offline
Old 04-26-2017, 01:57 PM
flash_xx
flash_xx's Avatar
Norm, is it me or did that tire rub on the strut? Also, can anyone confirm where the Koni yellows are currently manufactured?
flash_xx is offline
Old 04-26-2017, 02:17 PM
Norm Peterson
Believe it or not, neither the tire or the wheel rubbed on the strut. Not until I hit a couple of holes hard enough to flex the knuckle a tiny bit anyway (the wheel just barely nicked the paint). About 1.1, maybe 1.2 mm static clearance, feeler-gauge measuring.
There isn't going to be much lateral tire flex at the tire top when you're running a 35-profile tire on max-recommended-width wheels .
I have no idea where they were made. Sorry.
Norm
Old 04-27-2017, 01:51 PM
flash_xx
flash_xx's Avatar
Those are the 11" wheels? I was surprised how much clearance I have with the 10" wheels and 285 tires. Eyeballing it close to 1"
The question about the Koni's wasn't specifically directed to you. I know all the old Konis came from Europe. I had some on a previous car that lasted 11 years (or more, I sold the car with them on). My worry is where the new ones are coming from. My STR.T's are made in Argentina and are already rusted all over. I want "real" Koni's i.e made in Europe.
flash_xx is offline
Old 04-27-2017, 04:57 PM
Norm Peterson
Yes, 18x11. On the passenger side I had to make up a thin spacer (0.025") out of sheet aluminum to get about the same amount as the driver side (shown).
Norm
Old 11-24-2017, 07:17 PM
ourpony
ourpony's Avatar
Koni makes the spot shocks/struts for steeda. I was told by a steeda representative that they are similar STR.T’s although they are engineered to be compatible to the sport spring set up they sell
ourpony is offline
Old 11-26-2017, 09:42 AM
spectreman
spectreman's Avatar
I would not even attempt to challenge Sam Strano on his knowledge of suspension components. He knows his business exceptionally well.
The only comment I'd add is that, to me, Steeda makes/purchases/markets excellent quality stuff and if they're selling it, I would not hesitate to buy it from them. I'm a huge Steeda fan & have had a number of their products on my various Stangs over the years. IMHO, none has ever failed to live up to its reputation or performance value.
Lee
spectreman is offline
baddog671
07-26-2016 01:20 PM
jerrytubes
10-23-2015 12:11 PM
Florida Regional Chapter
09-30-2015 08:04 PM
UrS4
09-30-2015 10:13 AM
09-24-2015 09:18 PM
Quick Reply: Steeda Pro Action Shocks
