why did ford do that with the sway bars ?
My question is about why on the v6 mustangs (without pony package ) they only put the front sway bar on. Shouldn't they of put the back only If they were going to put only one. Since a v6 has less power than a GT ,they could even have a larger sway bar in the rear than the GT and get away with it due to it not power sliding as much as a GT. Or is it one of those things about giving it a little more under steer so that the average driver wont spin out as easy ? Tell me your opinion . Thanks
I think I also read the only gave the v6 210 hp so it wouldn't compete with the GT (you may be rite)
you really think it would do better in the rear?? i would think it would be more beneficial in the front. i'm no suspension guru though, so i may be wrong. and i dont know why they did it.
in a corner the outside front tire has more loading than any other, and that corner will tend to roll under- I believe ALL cars since the 50's~60's have had a front sway bar wether performance/truck/station wagon...without the front bar the car can become dangerously loose. My mark VII when the air suspension was leaking tended to break off the end links, aside from hearing the rattle, the handling really really changed for the worse- it works
Only cars Ive heard of not having one are some drag cars just to lose some frontend weight, but along with the skinny front tires, those cars are not built to be thrown into a corner...
also- look t the diameter difference from a front to rear sway bar- that alone will tell you which one does more
Most car manufacturers build their cars to understeer at the limit when cornering, i.e. the front end goes off the corner first. This is felt to be safer for the average driver in an emergency situation. To increase understeer you put an anti sway bar at the front. Adding one at the rear only would reduce understeer and probably result in oversteer,i.e. the rear end will break loose first at the cornering limit. This results in a spin if things really get out of control.
This assumes that you are not on the throttle when cornering. If you are and you have a GT, or better yet a GT with an SC or Turbo then throttle on oversteer is available on demand but you had better be careful
