Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 01-09-2009, 05:08 AM   #1
Jersey Stang
Jersey Stang's Avatar
Vehicle: 2006 Mustang GT
Question Steeda LCA's--Spherical Bearing or Poly Bushings
I'm looking to get Steeda Lower Control Arms very soon, and I'm tossed between the Spherical Bearing or Poly Bushings. Steeda recommends the Spherical Bearing for 500+hp. Since i'm near the limit (440rwhp) I'm wondering if I should go with the spherical bearing or if the poly bushing will do fine. I know there is some NVH with the spherical bearing, but I don't know how much. I'd like to hear from anyone that has either the Spherical Bearing (555-4406) or the Poly Bushing (555-4405). Any thoughts or suggestions?
Thanks
__________________
06 SATIN SILVER GT
SALEEN STAGE III POWERED BY BRENSPEED
STEEDA CAI
FRPP3.73's
FRPP STINGERS
GT500WHEELS
METER4IT CHASE LIGHTS
Jersey Stang is offline   Reply With Quote
Old 01-09-2009, 08:19 AM   #2
Jazzer The Cat
Wheels/Tires Section Moderator
2002 Ford Mustang
Jazzer The Cat's Avatar
Vehicle: '02 s281 #0014
You will get additional NVH running an aftermarket LCA with poly or spherical end(s). You will get more with a spherical, but less bind in axle articulation. If you visualize the rear axle with one wheel moving up/down in wheel well (articulating), you will see the LCA's need to rotate or twist lengthwise slightly to allow such movement. This is where the spherical joint is the way to go. The poly/poly ends will not allow this rotation without some binding. It is not a HUGE amount of binding, but your suspension action will be improved over the stock or poly/poly ended LCA's. When this suspension action improves, your handling/cornering will also benifit. I would also recommend an adjustable set as this can help with axle centering and can effect pinion angle as well. Although, I think the UCA is the preferred adjustment point for pinion angle issues. I don't know how to express how much NVH you will get, but this is a trade-off for a more properly operating suspension system.
Looking at the Steeda site, I don't see a pair I would like, but if I HAD to go Steeda, I would only purchase these:
These are really overkill as they have spherical (Heim joints) at both ends and really unnecessary.
I would MUCH rather go with a set of UMI set like the following that can be found at Sam Strano's site:
These are a wonderful set and offer the best of both worlds. Spherical/poly ends (greasable, to boot).
HTH
Jazzer
Jazzer The Cat is online now   Reply With Quote
Old 01-09-2009, 08:44 AM   #3
Doogie65
2007 Ford Mustang
Vehicle: 07 GT Alloy vert
I just picked up a set of the 555-4405 on ebay for a killer deal, but won't know until spring how they work out and if any major NVH is prevalent. I really wanted a billet set because I like they way they look, but there aren't many options. I had originally bought a set of the Roush billet's knowing they had rubber bushings and assumed they had the same ones used on the GT500 stock version, but later found out they were just stock rubber.
Another option I was considering were the J&Ms as there 3-piece bushing design does look intriguing. Had I not found this deal on the Steedas ($230 shipped) which I know are a great product, I was planning on going the J&M route as you can get them on their ebay store (Hotparts) for $218 shipped.
http://cgi.ebay.com/ebaymotors/BILLE...mZ170291332175
__________________
Mods: Edelbrock Supercharger 422RWHP/394RWTQ, CDC convertible bar & Classic Chin, Roush rear springs, GTAs, Steeda Billet LCAs & adj. panhard, CHE anti-squat, Pro5.0 shifter with Hurst stick/knob, RotorPro Rotors, Agent 47 mirrors, Dual Aeroforce gauges, CS69 wheels
Foose hood awaiting paint
Doogie65 is online now   Reply With Quote
Old 01-09-2009, 08:55 AM   #4
Jersey Stang
Right now my car is not lowered and I prefer the non-adjustable LCA's. If i decide to lower my car, i will buy adjustable Uppers. I know i will be deciding between only the two i mentioned, but not sure if i should go with the 4406 or if the 4405 will be more than enough. Doogie, that's a great buy. i wish i was searching ebay for that deal. Is there anyone that has Steeda's 4406 that can chime in? thanks
__________________
06 SATIN SILVER GT
STEEDA CAI
FRPP3.73's
FRPP STINGERS
GT500WHEELS
Old 01-09-2009, 09:15 AM   #5
Doogie65
2007 Ford Mustang
Although mine is slightly dropped via Roush springs (~ 1in.), I am with you and wanted fixed LCAs. I have not checked the pinion angle yet, but worse case is that I can put in an adj. UCA.
__________________
Old 01-09-2009, 09:29 AM   #6
Argonaut
Argonaut's Avatar
I can comment on the NVH - I have the Spohn poly/rod LCAs, UCA and PHB. Yes there is a small increase in N and in H but its nothing like some people make it out to be and I don't feel any increase in V. To me the articulation, lack of binding and solid mounts are way worth it over the slight increase in NH. I guess it all depends on what you are after. Heck, my exahust is a lot louder than any noise from the suspension.
__________________
07 GT 5spd: stock > road racing > stock.
Argonaut is offline   Reply With Quote
Old 01-09-2009, 09:56 AM   #7
BMRFabricationSales
Former Sponsor
Quote:
Thanks
Hello, a poly/poly control arm will work fine for your application but if you can tolerate a small increase in nvh and i mean really small the poly/rod combo arm will net you better performance not only at the drag strip but also in handling. The poly/rod arms articulate better and have less binding. We also offer a poly/rod arm along with several other designs. If you have any questions please give me a call.
BMRFabricationSales is offline   Reply With Quote
Old 01-09-2009, 12:32 PM   #8
Jersey Stang
thanks, I guess 4406 is the way to go. it will help me now and later on, if i decide to up the power
__________________
06 SATIN SILVER GT
STEEDA CAI
FRPP3.73's
FRPP STINGERS
GT500WHEELS
Old 01-09-2009, 01:32 PM   #9
07musclemustang
2007 Ford Mustang
07musclemustang's Avatar
Vehicle: 07 Mustang GT Rag Top
get the combo poly/sperical its the best way to go
__________________
07 GT Rag Premium, Black on Black
GT 500 Front End, Rear Spoiler Delete,
FRPP Hood Pins, Functional Hood Scoop,
PIAA 510 4300k Fogs, 4300k HID DRL Delete,
Steeda 90mm Intake and Tube, Steeda UDP,
BMR Combo LCA, UMI Poly UCA, BMR FSB Delete,
SCT Xcal 3, FRPP CMDP, Innovate Wide 02
PRO 5.0 Shifter, Custom T and Handle
Pypes Mid Muffs, FRPP X pipe
FRPP 4.10s and True Track
13.2 @ 109 at 2400ft above sea level
12.8 @ 111 DA corrected
07musclemustang is offline   Reply With Quote
Old 01-09-2009, 06:04 PM   #10
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Vehicle: 08 Mustang GT
Quote:
+1 - I'm seriously considering swapping out my Steeda adjustable poly/poly (555-4416) LCA's for the adjustable UMI poly/rod LCA's.
This is primarily to get the better articulation but also to get a poly bushing with a grease fitting.
My car is a DD but set up mainly for road course track days per my sig. I ran 6 days last year and hope to run at least that many this year.
__________________
White 08 GT Roush S/C 445 HP/KDW2 285/40/18 tires/18 x 9.5 Steeda Ultralite wheels/ Steeda Competition springs/D Specs/FAYS2 Watt's Link/LCA/Adj UCA & Mnt/Upper strut mnts/GT500 Brake Kit/GT500 Front LCA/X5 Ball Jnt/Bmp Str + more
Sleeper_08 is offline   Reply With Quote
4406, 555-4405, 555-4406, 5554406, bearing, binding, che, installation, lca, mustangforums, nvh, reviews, spherical, steeda, steeda lca
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
