ROUSH REAR SPRINGS
#32
best pricing on CHE stuff is at this site http://artsperformanceparts.com/
The rear items (panhard, LCA and springs) are all fairly easy to install with basic handtools, but for the front springs, you will need rent a good spring compressor to do it safely.
#34
[QUOTE]I just installed Roush rears only on my ragtop last month and did notice enough of a change with the rear to add a panhard bar. I just did the panhard bar last weekend and think the drivers side out off by about 5/8in. Nothing too severe, but I do plan on adding wider tires and wheels so I figured I might as well just put the adj. panhard on while I was installing the CHE brackets and Steeda LCAs.[QUOTE]
Per my previous comments, I did have some rear shift with only Roush rears installed. Here's a side profile shot that gives you a good view of the rake change. I figure by the time I drop in the Supercharger, the front will sit perfectly with the stockers.
09-08-2015 11:50 AM
