Bolt Sizes
Old 02-17-2009, 10:04 AM
Texotic
Texotic's Avatar
Default Bolt Sizes
Is there a place I can go to get all the sizes for the different bolts in our suspension? Since Ford was so kind to supply use with a bunch of awesome one-time-use bolts, I'll be replacing them with Grade 8 hardware from here on out any time I do an install. For now the sizes I need are for the Caliper and Caliper Bracket bolts and the Chassis and Axle side bolts for the LCA's.
If there is a comprehensive list somewhere, that would be great. I just want to know what I'm looking before before I get everything taken apart and would prefer to not have to spend all day driving around trying to match bolt sizes at the different hardware stores. If anyone has the FSM, it should have the sizes, right?
Appreciate it, guys.
Texotic is offline
Old 02-17-2009, 10:37 AM
Norm Peterson
Norm Peterson's Avatar
Whatever they are (can't get to my FSM on this computer), they'll be metric and will carry grade numbers that look like 10.x or 12.x. I'd be careful where I source any replacement fasteners.
Norm
Norm Peterson is offline
Old 02-17-2009, 04:13 PM
Texotic
Texotic's Avatar
Well, where would you trust getting them? Or would it be better to just keep buying replacements every time I take something off? It just seems like that would be annoying as hell.
Texotic is offline
Old 02-17-2009, 05:49 PM
Norm Peterson
Originally Posted by 90 5.0 at C-C.com
How 'bout a good source for bolts?
Originally Posted by gt40
IOW, what passes for "Grade 8" at places like Home Depot may be "iffy" in terms of quality control even though the fasteners carry six lines. While such bolts might be OK with OE-ish power levels and OE tires on regular streets, I'd be getting uneasy as power and grip levels rise (think R-compounds, Drag Radials, suspension upgrades, starting line prep, etc.) and as the average driving intensity goes up.
A little more tech:
You don't want the threaded portions of any fasteners placed in bending or in a "shear plane". Here, it's the threaded length that matters. And you don't want to cut more threads if the threaded length comes up short - cut threads are far less resistant to fatigue than the rolled threads that you should be using for fasteners as mission-critical as suspension pivots.
A lot of people who read threads like this won't make any distinction between moderate street driving and much more competitive types of driving, and I'd guess that very very few of us inspect suspension fasteners on any regular basis. I can't even say that I do.
Norm
Old 02-18-2009, 09:41 AM
Texotic
Texotic's Avatar
Is there a place online I can find the FSM, or do I just need to order one?
Texotic is offline
Old 02-18-2009, 12:57 PM
Vapour Trails
Vapour Trails's Avatar
I re-used all my hardware. Autoxed with Rs, drag raced with drag radials, I'm still alive. I know 2 other S197 autoxers that re-used all the original hardware, they are alive too. This is Ford CYA, because of the nylon inserts.
Vapour Trails is offline
Old 02-18-2009, 03:58 PM
Texotic
Texotic's Avatar
Well I'm going to have to get new bolts for my LCA's since BMR doesn't use metric openings. Don't want any clunking...
Texotic is offline
Old 02-18-2009, 05:08 PM
charliebrown266
charliebrown266's Avatar
+1 on the nylon inserts,that why i think they say replace them,also use some blue thread locker.
charliebrown266 is offline
Old 02-18-2009, 05:35 PM
Norm Peterson
If you make sure that the bushings (and I'm guessing that they are polyurethane) are no longer than their inner sleeves, the joint maintains adequate tightness just from the bolt torque. It's when the poly is longer than the sleeves it effectively robs some of the clamping force from the [bracket side] - [inner sleeve] - [other bracket side] stack that things move around and make noise. When the suspension moves, the poly rotates and any friction being developed with it essentially disappears.
Norm
Old 02-18-2009, 06:03 PM
tx_zstang
tx_zstang's Avatar
Texotic, I mostly reuse the same hardware when it will fit. However, I have also ordered some replacements (driveshaft bolts and a couple of LCA bolts) online I think from directfordparts.com or something like that. I called them and they looked up the part #s I needed.
Norm makes a very good point on the bolts, in that the threaded portions are not as strong as solid parts. Just be careful when using non-oem bolts for critical fasteners.
tx_zstang is offline
Quick Reply: Bolt Sizes
