New Features: Ford Mustang Knowledge Base
Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 06-23-2009, 10:27 PM   #21
TennTex
TennTex's Avatar
Quick summary of my experiences with pads. Starting a few years ago on an '06 330i I ran Hawk HT-10's Front and HP+ Rear. (I had HT-10's on the back as well, but it was too much grip on the 330i in the rear and made the car squirly.) The Hawks stopped great, but my car squealed like a freight truck! They dust a lot, which is not a problem, but they are iron-based, and basically form a carbide on the wheel which I had to use CLR cleaner to work the spots off. I moved over to Carbotechs, but then got my Shelby GT.
I've had 2 track events with my 'stang with XP-10 Front / XP-8 Rear (stock calipers/rotors). On the 2nd day at MSR in May I started getting a long pedal. I've decided that I need to add air ducts, and will be installing soon. I have finally started getting used to the car and pushing it harder, and I noticed more wear than usual on the pads. I think I can get one more HPDE weekend out of them. Note that I also use another set of rotors for the front, so I can have one street and one track. I haven't bothered doing this for the rears.
__________________
2008 Shelby GT
1991 Mustang GT
Texas HPDE: www.thedriversedge.net
TennTex is offline   Reply With Quote
Old 06-24-2009, 07:18 AM   #22
Gene K
In answer to the original question of weight. A base 2007 GT Deluxe with spoiler delete should have had a shipping weight of 3348 lb.
2007 GT Deluxe with Spoiler and 3.55 Option
MSO Shipping Weight - 3353 lb
Actual Weights on Scale (6 gal fuel and no driver):
Total - 3420 lb
Front - 1860 lb
Rear - 1560 lb
Distr - 54 / 46
__________________
Gene
2007 GT-D M5 3.55 3700 lb (280 lb Driver)
CAI/Tune and Stock Pirellis
1.909 8.345@84.83 12.957@106.62
http://i253.photobucket.com/albums/h...nePirellis.jpg
Gene K is offline   Reply With Quote
Old 06-24-2009, 12:00 PM   #23
Argonaut
Argonaut's Avatar
Your results and comments concur with mine: The HT-10s work great but squeal like a MFer. The Carbotech seem to wear out fast. Thanks for the info.
__________________
07 GT 5spd: stock > road racing > stock.
Argonaut is offline   Reply With Quote
Old 07-05-2009, 12:55 PM   #24
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Vehicle: 08 Mustang GT
My car is a DD used for road course track days. It has the GT500 brake kit and Quantum front cooling ducts. I want to run the same pads for street and track days.
Last year was my first time for tracking a car. I ran Ferodo DS2500 pads on the front and Hawk HPS on the rear. I got 6 track days out of the pads and they were worn about 50%. There was significant dusting on the track and some on the street but my main objection was brake squeal. The pads performed well on the track and the street.
I switched to the EBC Yellowstuff pads front and rear this year. Yesterday was my fourth event this year. Two were on a short tracks, TMP, which is hard on brakes and two were at Mosport which is a much faster track and not as hard on brakes.
I have been watching the front pad wear and so far they are down to about 1/2 thickness. After yesterday the rears however are toast and almost completely worn out!
This surprised me. I wonder if it is because the front brake cooling helps the front pads last longer even though they do most of the work?
I'm now considering going to Hawk HP Plus for the rear. The alternative would be back to Hawk HPS but they may not hold up as I am getting better at this and am going faster than last year.
All suggestions and comments would be appreciated.
__________________
White 08 GT Roush S/C 445 HP/KDW2 285/40/18 tires/18 x 9.5 Steeda Ultralite wheels/ Steeda Competition springs/D Specs/FAYS2 Watt's Link/LCA/Adj UCA & Mnt/Upper strut mnts/GT500 Brake Kit/GT500 Front LCA/X5 Ball Jnt/Bmp Str + more
Sleeper_08 is offline   Reply With Quote
Old 07-06-2009, 09:07 AM   #25
Red06
Red06's Avatar
Vehicle: 2006 Mustang GT
Do you remember to turn traction control off? With your boosted Mustang, the TCS may be detecting wheel spin coming out of corners which will use the rear brakes to control it. That would explain the excessive rear wear in the rears.
I have five days on mine and I have maybe 1/4 to 1/3 left on the front (I have ducts too) and the rears still have some of the taper left in them so I'd say 3/4. I remember to turn the TCS off most of the time but I'm not boosted either.
I've been looking at going to the Cobalt pads to see if I can get rid of the late session pad fade I still get with the EBCs. The XR 1s seem to have a very wide (advertised) operating range, 100 - 1600 degF, which would allow me to still run one set of pads for occasional street use and on the track.
__________________
Mods: Corsa Exhaust, Steeda: Complete Intake, UDPs, HD Strut Mounts, G-Trac, Panhard Brace & SS Lines, Eibach Pro Kit, Tokico D-Spec, Spohn: Adj. LCAs & Panhard Bar, BMR: UCA & Reloc Brkts, Coast AL DS, Strange STB, Cobalt Friction Pads, ATE Fluid, Quantum Ducts, ARH LTs, Prothane MM
Red06 is offline   Reply With Quote
Old 07-06-2009, 05:46 PM   #26
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Thank for the response. I usually remember to turn traction control off but sometimes forget so that might have contributed to the high wear rate. In future I'll try to do a better job of remembering.
My front are probably about the same as yours after about 4 sessions.
This morning I ordered HP+ for the back and a spare set of HP+ for the front. Meanwhile I'm taking public transit until the rear pads are here and replaced
__________________
Old 07-06-2009, 09:20 PM   #27
Red06
Red06's Avatar
Bummer about the public transit... I forgot you have the GT500 front brakes. Maybe there is a bias issue with the brakes. If the switch to the Hawk brakes doesn't work you may want to look into a manual proportioning valve so you can dial in more front bias. That has always been my concern with the big brake kits that switch out fronts only.
Good luck
__________________
Old 07-06-2009, 10:04 PM   #28
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Good luck
I was wondering the same things about the GT500 front kit. Last year when I was running the Ferodo DS2500 on the front and Hawk HPS on the rear I ran 6 track days plus maybe 6,000 road miles and the fronts had from .12 to .16 left and the rears from about .18 to .22. According to Hawk the their front pads new are .585 front and .656 rear. Assuming that the Ferodo pads had the same initial thickness then last season I got about the same wear rate front and rear.
Does anyone know if a stock GT500 has a different front/rear brake bias than the stock GT?
__________________
Old 07-24-2009, 09:12 PM   #29
Argonaut
Argonaut's Avatar
What do ya think? Did I get my money out of these?
Rear CarboTech XP8 after 8 dry track days and 2 wet (which don't really count). Only two of these days were on a track I'd call hard on brakes.
__________________
carbotech, cooler, daily, deposits, driving, hps, measure, mustang, pads, review, s197, swap, track, xp10, xp8
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
