Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 07-06-2009, 11:58 PM   #11
Vapour Trails
Quote:
Originally Posted by jahudso2 View Post
yeah i was thinking the rear end would move if i didnt load the suspension, but the directions that they sent me said to "support the vehicle at a safe working height with the suspension hanging freely." These directions came directly from the LCA manufacturer, but it was a writeup from stangnet. You would think they would give you correct instructions from the factory.
I got those same instructions, they are not correct.
Anyway, if you've got the frame supported you can always use your hack to raise the diff and compress the suspension.
__________________
Whipple @ 9 psi - 445rwhp/400rwtq - 12.07 @ 118.7 mph
Steeda sport springs - Steeda strut mounts - Steeda TriAx- Steeda Adjustable Panhard Bar - Steeda Axleback - D-Spec shocks - J&M LCAs - FRPP 4.10s - GT500 spoiler -
And probably more I can't remember
All work done by owner
Vapour Trails is offline   Reply With Quote
Old 07-07-2009, 09:13 PM   #12
jahudso2
Send a message via AIM to jahudso2
Yeah, just make sure you do that BEFORE you remove the stock LCA bolts. It is a huge PITA trying to push the rear axle across the pavement while its jacked up, especially when your jack wheels sink into the crappy pavement in your apartment parking lot.
__________________
2008 GT Manual
JBA Ceramic Shorties
Pypes O/R H-Pipe
Corsa Axle-back
FRPP 3.73s
D-Specs
Stillen Sways
J&M LCAs
Join us in the NC Mustangs Social Group.
jahudso2 is offline   Reply With Quote
Old 07-08-2009, 11:59 PM   #13
Glengemen
Glengemen's Avatar
Mabey it is that I have done it so many times, but I didnt have much difficulty doing mine, but I removed the rear axle all together and did an adjustable UCA, LCA, relocation brackets, and sanded/painted the rear axle. Later I added an adjustable PHR and PHR brace.
But the parts do make one hell of a differance, especially on a lowered car. I dont have track times to proove it, but I could spin through 3rd before, now I am planted at the bottom of second.
By the way I would not advise anyone take loose loaded suspension parts on jackstands in a parking lot.
__________________
2006 Vista Blue GT 5 speed
20" AR Roques W/ Proxes T1R, 1.5" springs. Steeda Tri-AX, JLT CAI, CHE K member brace with torque limiters, Anti squats, UCA, LCA
Glengemen is offline   Reply With Quote
Old 07-10-2009, 05:02 PM   #14
white_lightning
white_lightning's Avatar
Vehicle: 2007, Mustang GT
thanks for all the tips guys,
white_lightning is offline   Reply With Quote
Old 07-20-2009, 10:19 PM   #15
tfedorka2001
Vehicle: 2006,ford,mustang gt
When I did my LCA's I did one side at a time and then I loaded the rear to torque everything down. I didn't have any issues with the rearend moving. The UCA was a pain because I didn't take the bracket all the way out and I had a hard time getting the right torque on it.
tfedorka2001 is offline   Reply With Quote
2007, adjustable, arm, arms, brackets, control, difference, gt, install, jm, lcas, lower, mustang, relocation, steeda, upper
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
