As far as I know, TCS is fully turned off when you switch it off.
Quote:
Originally Posted by jahudso2
. . . if Ford had included a nice stability control program to let you explore the limits of the car without quite as much risk involved. You don't have to use the system if you don't want to, so why would you be against it?
Because it teaches you that it's OK to be clumsy with the controls when you're driving up around the limit. If you don't have to worry about being 'smooth' while driving hard ('smooth' being a good thing for both safety and passenger comfort), you'll never learn. And if you don't/won't/can't learn, you have no business driving that hard.
Because it leads to a mindset that accepts less responsibility for own personal safety, replacing that with the blind acceptance of somebody else's automated decisions.
As a driver, your skill level stops improving when you start counting on these systems to step in and keep you out of trouble -
just like with the initial question, if you rely on TCS to suppress wheelspin you'll never learn fine throttle modulation.
As a tinkerer/occasional modifier I resent anything that would interfere with or otherwise reduce the effectiveness of efforts to improve performance.
FWIW. Some of these stability control systems either cannot be completely turned off, or may automatically reactivate themselves under certain conditions in spite of being intentionally switched off. I think ABS activation is one such trigger in some systems (and I think I read where BMW's is one example).
Want to learn the limits of your car (and yourself!) in a safe environment? Find an autocross. It's that simple.
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
