Both Rear Axles Are Bent?? How The H*ll
Old 08-22-2009, 02:03 PM
  #31
SoulBurn18
SoulBurn18's Avatar
I have no idea why there are so many holes. I just gave them my car and said "Have At It." So I don't know if they came that way or if they did it afterwards.
SoulBurn18 is offline
Old 08-22-2009, 02:18 PM
  #32
Sleeper_08
Sleeper_08's Avatar
Originally Posted by 157db
Lets see, I see a S197, a tire, a rim, a caliper and a rotor in that picture.
Yes, one of those items is a caliper.
The 14" refers to the rotors diameter.
Calipers are specified differently and not in inches....
2 piston full floating, 4 piston full floating, 6 piston full floating
and so on. So it still stands that those are not 14" CALIPERS.
14" rotors, maybe.
Whats the reason behind all those holes drilled into your ROTORS?
Thats where they will start stress cracking first, btw...
Only if you brake the car hard enough to really heat up the rotors
Sleeper_08 is offline
Old 08-22-2009, 02:20 PM
  #33
SoulBurn18
SoulBurn18's Avatar
I don't brake hard very often.
Old 08-22-2009, 02:23 PM
  #34
157dB
Cut & Paste Expert
157dB's Avatar
Thens yous will bees okays.
They were drilled in the past to allow brake pad gasses to escape.
Its old tech thats not needed anymore...
Pars dont gass nowdays....
But rotors still get drilled.....
157dB is offline
Old 08-22-2009, 06:22 PM
  #35
Hootna
Hootna's Avatar
Axles on clearance... I bought these a few months back when I replaced my bearings.. figured good time to upgrade.
http://store.roushperformance.com/detail.aspx?ID=999
Hootna is offline
11-10-2015 11:39 AM
firecoyote
09-27-2015 02:37 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-10-2015 08:39 PM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Both Rear Axles Are Bent?? How The H*ll
