Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 08-26-2009, 02:36 PM   #1
dvs4.6
dvs4.6's Avatar
Vehicle: 2008 WHITE FORD GT
Default Squeaky rear suspension?
I have noticed that my rear end suspension is a bit squeaky, i do have H&R RaceSprings, Tokico shocks, and STeeda SB's. i checked all of the nuts and bolts and everything looks just right. i did read somewhere on this site about the rear somethings needed to be loosened and retightened when performing rear suspension work. i believe some part would pre-loading (don't quote me on that one) if not loosened then re-tightened. any help much appreciated.
squeaks even on the smallest of bumps or dips.
__________________
2008 White GT
BBK CAI
Steeda F/R swaybars
H&R Race springs
Tokicos, FRPP X-pipe, UMI LCAs
GT500 wheel set, spoiler delete, QMS Brake Ducts
FRPP strut tower bar, FRPP Exhaust, Hawks HP+, Goodridge brake lines, CDC chin spoiler, UMI PanHard Bar.
dvs4.6 is offline   Reply With Quote
Old 08-26-2009, 05:02 PM   #2
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Vehicle: 08 Mustang GT
By SB do you mean LCAs? If so these bolts on the LCAs are supposed to be tightened when the weight is on the wheels,i.e. the car is on the ground.
If your LCAs are poly bushings then this can cause squeks if they were not liberally greased with the grease that came with them.
One way to get rid of the squeks is to go to rod ends but then you get different noises
__________________
White 08 GT Roush S/C 445 HP/KDW2 285/40/18 tires/18 x 9.5 Steeda Ultralite wheels/ Steeda Competition springs/D Specs/FAYS2 Watt's Link/LCA/Adj UCA & Mnt/Upper strut mnts/GT500 Brake Kit/GT500 Front LCA/X5 Ball Jnt/Bmp Str + more
Sleeper_08 is offline   Reply With Quote
Old 08-26-2009, 05:41 PM   #3
chopin0302
2008 Ford Mustang
Vehicle: 2008 GT/CS
+1 on greasing the bushings, however I would add a good cleaning too. Having gone through the exact same thing myself (front end) that would be the first thing I would check. I live in El Paso, which is very dusty, so I would have to clean and re-grease all bushings about once every three months. I first made sure all the components were torqued to spec, when that did nothing I went ahead and removed the front and rear sway bars and lca's. I cleaned them (they were very dirty) and then liberally applied 100% silicone grease and the squeaks/groans were gone. I did this work myself on a base hobby shop as a lift makes things much easier. Hope this helps.
__________________
2008 GT/CS Black w/Dove Accents
Manual
BMR Front and Rear Sway Bars
Billet LCA's, Tokico D-Specs
chopin0302 is offline   Reply With Quote
Old 08-27-2009, 06:23 PM   #4
dvs4.6
dvs4.6's Avatar
i meant to say sway bars (SB's) and i researched the site and found a thread on the loops in which the brake lines run through that may be causing the problem. i will look into this over the weekend.
__________________
2008 White GT
BBK CAI
Steeda F/R swaybars
H&R Race springs
2006, 2008, car, cost, end, front, gear, mustang, rear, shocks, specs, sqeaky, squeak, squeaking, squeaky, suspension, tokico
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
