Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 09-18-2009, 05:27 PM   #1
14901490
14901490's Avatar
Vehicle: 2005 Mustang GT
Default Raybestos ST43 Anyone
So after doing a search here i find no info on the ST 43 brake pad.
The reason i ask is they were suggested to me by a ' Vette guy as being superior to the HT 10 or HT14 for trac kuse.
I realize the brake bias is set up differently on the Mustang , but am wondering if anyone has tried these & impressions ?
Thanks
14901490 is offline   Reply With Quote
Old 09-18-2009, 09:12 PM   #2
Argonaut
Argonaut's Avatar
Im around Vette guys a lot and I can't say I've ever even heard of it. Carbotech, PFC, Hawk and Cobalt Friction are all popular, Willwood also (for those with Willwood calipers).
__________________
07 GT 5spd: stock > road racing > stock.
Argonaut is offline   Reply With Quote
Old 09-18-2009, 09:49 PM   #3
14901490
14901490's Avatar
Quote:
whats your current preference?
Old 09-18-2009, 09:52 PM   #4
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
There is a guy in NorCal that has used them with success in TT on his S197. He also uses the 41's. He said they last 5-6 weekends but are just as hard on rotors as the others. He gets them thru Porterfield.
__________________
Thanks to Wild Pony Motorsports, Ross Murray, and Agent 47.
RodeoFlyer is offline   Reply With Quote
Old 10-17-2009, 08:29 AM   #5
14901490
14901490's Avatar
Well I bought a set of the ST 43 for the fronts - so as soon as my HT 14 are spent I'll post a report . Looking like next season unless I get south before ..
Thanks
Old 10-17-2009, 05:28 PM   #6
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
You may want to have a set for the rear ready as well. I've found that if you don't step up the rears the bias is such that the car isn't happy out back, and trailbraking becomes a little dicey.
__________________
Old 10-17-2009, 10:01 PM   #7
14901490
14901490's Avatar
Quote:
my current set up is
front stoptech st 40 calipers (Saleen BBK ) on slotted 14 " rotors with ht 14
REAR IS STOCK WITH HT 10.
no bias issues now - but with the new st 43 on front you feel i'll want the same on the rear?
Old 10-19-2009, 05:24 PM   #8
Argonaut
Argonaut's Avatar
You learn something new everyday...and here is something I learned just the other day from a very respected former World Challenge driver and coach:
- The usual advice you see with regards to Front vs Rear pads is that the rear pad should be 'lesser' than the front. For example the conventional wisdom is to run HT-14 on Front and HT-10 on rear, or Carbotech XP10 on front and XP8 on rear, etc.
- I have always questioned this, it didn't make sense to me. My thinking was that factory systems are heavily front biased for safety and therefore I was giving up some rear stopping power by putting a 'lessor' pad in the back. Even though I have always followed this advice, I was thinking about changing and going to the same pad front and rear in an attempt to get the rear to do a little more of the work.
- But here is what I learned - the reason we use a lesser pad in the back has nothing to do with the coefficent of friction or stopping power of the pad. It has to do with the optimum temperature for the pad. Different pads provide their peak performance at different temperatures. So in a front weight biased car like the mustang, that relies heavily on the front brakes (what....70+% of braking done by the front?), the temps out front are going to be much higher than the rear. Hence we use a lesser pad on the rear because it works better at a lower temp.
- So (assuming this is correct) in theory it means you could actually be giving up stopping power by using same pad front and back, depending on the pad of course and its optimum operating temp.
__________________
Old 10-19-2009, 06:41 PM   #9
14901490
14901490's Avatar
Interesting that you bring that up as I was also wondering the same thing - why not make the rear do more of the work ?ie put a more aggessive pad on the rear ??
Old 10-19-2009, 07:08 PM   #10
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
Hi Argo -
Not to disrespect any World Challenge drivers, as I am friends with a few -
Is your friend familiar with the S197 Mustang? More importantly, is he familiar with Electronic Brake Force Distribution - which the S197 Mustang has?
The basis of the system is that it works in conjunction with the ABS, sending pressure to the braking wheel needing it most. Considerably more braking is done in the back than in days of old. This is also combined with a platform that has much better weight distribution than ever before - i.e : more weight in the rear now - more braking done in the rear.
I've proven it in the real world, trying various compounds and variations front and rear myself. The car is much better under braking when you run the same compound in the back. Your rear pads will last a lot longer as well, since you wont be cooking them.
__________________
43, brake, buy, forum, front, motorsports, mustang, pads, pony, raybestos, rotors, st, st43, street, wild
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
