Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-10-2009, 01:00 PM   #1
EF 07GTCS
EF 07GTCS's Avatar
Vehicle: 2007, GT/CS
Default Want some WHOA B4 more go, who makes better brakes?
Anyone-
I'm looking for brakes who makes good ones that are good for everyday use and don't require keeping heat in them in order to work well.
I don't want drilled rotors don't care for the looks of them plus I don't want to keep checking them for cracks.
I've been looking at the Steeda 14" 4-piston fronts and 13" rears or the Roush 14" front and replacement rear rotors.
Steeda says their brakes work with the ABS system better than the competitions, Anyone know if there's any validility to changing out the rotors and then having issues withthe ABS?
Looking forward to the opinions.
E
__________________
GTCASPL
Born on Date:23 March 2007 - Arrival Date: 15 May 2007/ M2005FR3 - Ford Racing Handling Pack /M7210T1 - Ford Racing Short Throw Shifter (Hurst) / M52305GT - Ford Racing Exhaust / Roush Rear Spoiler / 9" Black Shorty Antenna / 3.55 Factory Gears/ M-1007-S1895B Wheel/ Hankook Ventus V12evo Tire (P255/45/ZR18)
EF 07GTCS is offline   Reply With Quote
Old 10-10-2009, 01:05 PM   #2
EdwardGT
Steeda, Roush and Saleen BBK's are all OEM'd by StopTech. That being said, ST brake kits are designed to be used with the OEM ABS and OEM brake boosters.
-Edward
EdwardGT is offline   Reply With Quote
Old 10-10-2009, 02:39 PM   #3
foolio2k4
stop tech and AP racing get my vote.
__________________
2007 White Mustang GT
HID kit 6k, Steeda UDP, K&N FIPK Cold Air Intake, SCT x3 Canned Tunes, Magnaflow Cat-Back Exhaust, Magnaflow Catted X-Pipe, Prothane Motor Mount, Steeda Strut Tower Brace, Stillen Adj. Front and Rear Sway Bars, Steeda HD Panhard Brace, Steeda Billet LCA, Clear/smoked front and rear sidemarkers, LED turn lights, SHR Tru-Billet FD, JBA Shorty TC, APR Perf GTC-200 CF Wing, Steeda CMDP, APR Dry Carbon Mirrors, Mishimoto Alum. Radiator, TEIN FLEX Coilovers
foolio2k4 is offline   Reply With Quote
Old 10-10-2009, 04:05 PM   #4
RodeoFlyer
RodeoFlyer's Avatar
Vehicle: '06 GT /
Quote:
AP Racing is the redheaded stepchild of Brembo.
Stoptech uses Chinese rotors.
__________________
Thanks to Wild Pony Motorsports, Ross Murray, and Agent 47.
RodeoFlyer is offline   Reply With Quote
Old 10-10-2009, 06:46 PM   #5
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Vehicle: 08 Mustang GT
Why do you think you need a BBK?
If you are running your car on a road course then there are lots of mods to improve braking that are effective and cheaper than a BBK. One of these is better tires.
IMHO if you are running your car only on the street then a BBK is just window dressing.
__________________
White 08 GT Roush S/C 445 HP/KDW2 285/40/18 tires/18 x 9.5 Steeda Ultralite wheels/ Steeda Competition springs/D Specs/FAYS2 Watt's Link/LCA/Adj UCA & Mnt/Upper strut mnts/GT500 Brake Kit/GT500 Front LCA/X5 Ball Jnt/Bmp Str + more
Sleeper_08 is offline   Reply With Quote
Old 10-10-2009, 07:25 PM   #6
157db
Got Troy'd
157db's Avatar
Vehicle: 2007 Pony Package
Quote:
Originally Posted by EF 07GTCS View Post
Anyone-
S197 ABS works with whatever size rotor you choose.
Its not that sensitive to rotor size.
If the wheel locks up, the ABS modulates the pressure
to that caliper. Period. S197 ABS cares not the rotor size,
just the wheel lock-up during hard braking.
Internal caliper volumes do have a direct effect on the modulation.
So caliper replacement with aftermarket is what to worry about...
__________________
NON PUMKIN JACKER
Quote:
Originally Posted by Boozshey View Post
Oh yeah, I forgot Norm was God on here.
Give me a break!!!
Quote:
Originally Posted by Norm Peterson View Post
<rises to the bait>
. . . Definitely not God.
Norm
157db is offline   Reply With Quote
Old 10-10-2009, 11:57 PM   #7
Philostang
2006 Ford Mustang
Philostang's Avatar
Vehicle: 2006 Mustang GT
To the OP,
Lots of folks who hang out in this section try to be genuinely helpful. However, without more information about your needs, problems, and expectations, any opinions offered are going to be a shot in the dark.
There are a lot of really BAD opinions and misinformation spouted out about brakes (esp. on the internet), most of it horrifically costly. Some of it is just due to a basic lack of knowledge; so folks end up thinking they need one thing when they really don't. Alt. folks may think there is a problem to avoid that isn't really anything to worry about. For example, you worry about some "brakes" needing heat in them to work well. This is a confusion. Some brake pads require heat in them to work optimally, but these are all track-only pads (i.e. race pads) not the street pads found in virtually all systems (and available for absolutely all systems). So when you're looking at a bbk (which means calipers along with pads), you needn't worry about heat range.
Some of what you say is hard to decipher for us. You want brakes that work well for a daily driver. Well, that would be the OEM brakes. Ford saw to it that they work pretty darn well for that duty. You say you don't want to check for cracks. To my mind that says "I'm not tracking my car," because if you were on a regular basis you would be always checking up on your rotors for the inevitable cracks. It sounds like you just want "some sort" of upgrade over stock. Too fuzzy to be of help.
So let's take it from the beginning. You're looking for brakes. Why? As Sleeper asks, what is happening that makes you think you need a better brake system (as opposed to merely better stopping power, a more confident pedal feel, a "cool" look filling up the wheel space, etc.)? Sleep mentioned the tires, but you seem to already have a decent set. The first step is to tell us what ails you currently and what your goals are for your braking system.
Best,
-j
__________________
2006 Mustang GT Premium: Tungsten...w/upgrades.
"We accelerate from corners, not christmas trees, and the length of our drag strip is dictated by the distance to the next braking area." -Carroll Smith
http://www.hubgarage.com/mygarage/DrJohn
Philostang is offline   Reply With Quote
Old 10-12-2009, 01:25 AM   #8
EF 07GTCS
EF 07GTCS's Avatar
Quote:
Originally Posted by Sleeper_08 View Post
Why do you think you need a BBK? at the current time it's for looks. When it's not my main transportation it'll be for track days, autocrossing, etc.
If you are running your car on a road course then there are lots of mods to improve braking that are effective and cheaper than a BBK. One of these is better tires.I'm all ears as the wife wasn't to excited when I told her that it can cost as much as $3-$4000
IMHO if you are running your car only on the street then a BBK is just window dressing.see abov reply
Quote:
Originally Posted by Philostang View Post
To the OP,
Some of what you say is hard to decipher for us. You want brakes that work well for a daily driver. Well, that would be the OEM brakes. Ford saw to it that they work pretty darn well for that dutyblame the magazines and t.v. car shows, a lot of their test say the stock brakes start to fade a little after a couple of laps, I know you can't always beleive what you read, but.... You say you don't want to check for cracks. To my mind that says "I'm not tracking my car," because if you were on a regular basis you would be always checking up on your rotors for the inevitable cracks. nope not tracking it yet, I plan on it someday though It sounds like you just want "some sort" of upgrade over stock. yes I do Too fuzzy to be of help.
So let's take it from the beginning. You're looking for brakes. Why? As Sleeper asks, what is happening that makes you think you need a better brake system see the reply ablut magazines and t.v. shows(as opposed to merely better stopping power, a more confident pedal feel, a "cool" look filling up the wheel space, etc.)? yes, I want better stopping (just because I think I'd like it) Sleep mentioned the tires, but you seem to already have a decent set. i've only put about 400 miles on 'em so far and I think I like'em The first step is to tell us what ails you currently and what your goals are for your braking system.I don't really have any 'ails' but coming down from 120 plus I'd just like to feel extra confident that the car will stop and will/ can do it in the shorest distance possible
Best,
-j
Plus I see (read) a lot of people add power to their cars but don't do anything to help stop all that power in a hurry if needed. I know I don't everything as safely as I should, but I do like to try.
E
__________________
GTCASPL
Old 10-12-2009, 02:00 AM   #9
Hootna
Hootna's Avatar
You would have no issues with either Steeda or Roush BBK they are both great companies. Now as to Steeda saying their system works better with ABS I think that is marketing and am sure Roush would say the same. The stock calipers and rotors will work well with upgraded lines, pads and fluid but if you want to upgrade brakes and got the money go for it. I am running a BAER kit and have had no issues with the ABS and found that the most important thing to be pad compound choice and remembering to order Vette brake pads when buying my replacement's...
__________________
2005 Roush
Hootna is offline   Reply With Quote
Old 10-12-2009, 08:59 AM   #10
Argonaut
Argonaut's Avatar
Tell your wife to relax - you don't need to spend 3-4K for your stated use. For AX you don't need to do anything. For consistent stops from 120, yes, you do need to work on the brakes: good pads and hi-temp fluid is all that is really needed, maybe throw in some stainless steel lines and you'll be good to go. For occasional track work, the Hawk HP+ or equivalent will be OK while still streetable. But for more confidence and better performance you will need a true track pad, something like Hawk HT-10, DTC60, Carbotech XP10, etc. Personally I find that the HT-10 and XP10 both heat up so quick that I have no "cold" issues using them on the street (but then I'm not a tailgater either, always leave a margin for error on the street). But they have drawbacks - dusty and noisy. Your best bet is to have a set of street pads and a separate set of track pads. If you go with Carbotech, their compounds are compatible, so you can run the Bobcat pad on the street and the XP10 on the track with no re-bedding required.
__________________
07 GT 5spd: stock > road racing > stock.
Argonaut is offline   Reply With Quote
brakes, mustang, oem, s197, track
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
