Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-19-2009, 08:59 PM   #21
14901490
14901490's Avatar
Vehicle: 2005 Mustang GT
SO, my plan is - 1. 3.73 GEARS & rebuild the traction lock at the same time
2. Get a data acquisition system & camera to further improve my driving.
& later on do the Ford racing cam, throttle body & delete plates .
14901490 is offline   Reply With Quote
Old 10-19-2009, 09:07 PM   #22
Rubrignitz
2007 Ford Mustang
Rubrignitz's Avatar
Vehicle: 2007 Mustang GT Coupe
Do yourself a HUGE favor and toss that trak-lok. You can pick up a detroit tru-trac or torsen-type for ~$400. No more friction modifier and MUCH better cornering traction.
You will come out of corners like a banshee.
__________________
2007 Alloy GT Coupe/MGW shifter/C&L Racer CAI/JBA LT's/JBA catted H/Pypes M-80 race mufflers/Steeda HD engine mounts/LFP 17# driveshaft/FRPP 4.10s/Truetrac/Steeda Ultralite 18x9.5's with 275/40 and 285/40 Nitto NT555/Autometer DPSS shift light and gauges. Suspension: Steeda Comp Springs/GT500 Front CA's with Steeda X5 balljoints/Steeda bumpsteer kit/Tokico D-Specs/BMR adj upper & lower LCAs+relocation brackets/Hotchkis 3/4way adj swaybars/UMI Performance panhard.
Rubrignitz is offline   Reply With Quote
Old 10-22-2009, 09:36 PM   #23
14901490
14901490's Avatar
Thanks for the tip,
After much research & reading , I ordered the Detroit True Track to put in with the new 3.73 gears .
Old 10-22-2009, 10:18 PM   #24
14901490
14901490's Avatar
Will let you know how it goes!
__________________
05 GT Sonic Blue, H&R RSS struts & springs,Stillen adjustable sway bars, Enkei RPF1 18x9.5, Hoosier R6 275/35/18,Saleen BBK,Quantum MS Airducts, JLT CAI,MGW shifter, Basanni Race Mufflers,Corbeau FX1 seats,Momo Tuner steering wheel,3.73 gears, Detroit Truetrac
Old 10-25-2009, 04:02 PM   #25
14901490
14901490's Avatar
Quote:
Originally Posted by Sam Strano View Post
Well, I'd recommend 3.73's, a light flywheel, and a one-piece aluminum driveshaft. The gears will simply give the car more grunt. The other two shed rotational mass and that allows the engine to rev more quickly. For that matter, a light set of wheels is big too as they are 4 big flywheels themselves.
what is a good light weight track wheel that comes in 18 x 9.5 so i can run 275 s?
__________________
Old 10-25-2009, 04:04 PM   #26
14901490
14901490's Avatar
Also can anyone tell me for sure what the steeda ultra light 18 x 9.5 actually weigh- cant find it on steeda site ?
thx
__________________
Old 10-26-2009, 04:55 AM   #27
2007GT/CS
2007 Ford Mustang
Vehicle: 2007, Ford, Mustang GT/CS
Quote:
thx
According to Steeda (via email): 24.4 lbs. Not exactly 'ultralight'.
As mentioned above by a lot of smart guys on here, there are cheaper, lighter alternatives but it depends on what you are after. If you are keeping the 'stockish' brakes you can go down to a 17" wheel and save all kinds of weight, money in terms of tire pricing, and pick up a little effective gear ratio.
Good luck!
__________________
Saleen S/C - 432 RWHP/406 RWTQ - Hurst - Spydershaft - 4.10s - Bassani mufflers
Koni - Vogtland - J&M UCA/LCAs - Saleen Watts Link - 5zigen FN01r-c 18x9.5
2007GT/CS is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
