Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-20-2009, 09:14 PM   #1
Chevy Convert
Vehicle: '05 GT
Default Stock Bullitts 17 X 8 Tire Size
It's about time to put the Pirelli's to rest. I'm stock ride height and want the largest tire (same all four corners) that will maintain the existiing gap or maybe close it up maybe a little bit. I've searched and it looks like 255/50/17's? I don't want side wall roll and would like to maintain or improve handling.
Snow and ice is not a factor and I don't drive in the rain much. Outside of size, what brand for some good grip?
__________________
White '05 GT: Flow AT's, MRT Catted H Pipe, JLT2 CAI, Brenspeed 91 tune, Steeda UDPs, FRPP 4.10's, Coast Alum DS, Hurst Shifter, BMR LCA's, Pan Hard rod/brace, rear sway bar, DS Loop, CHE K Mmbr brace w/ torque limiters, Summit COP's, 20% tint
Chevy Convert is offline   Reply With Quote
Old 10-20-2009, 09:31 PM   #2
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Send a message via AIM to Nuke Send a message via Yahoo to Nuke
255/50/17's are only .14" shorter than the stock 235/55/17's. That's well within a change that won't require a speedo correction. However, I think you'll find you don't have as wide a selection of tires in that specific size.
There are a lot of grippy tires and it depends on what you want to spend. I put SOME faith in the ratings on sites such as tirerack.com. And I like how my Goodyear Eagle F1 all seasons handle but I don't drive in snow with the Stang so I should have gone with a summer high performance tire. Have fun! Lot's of choices.
__________________
Rick
07 GT Prem: Alloy, MT, 3.55's, Steeda CAI w/Brenspeed tunes, FRPP Stingers, 275/40/18 Goodyear Eagle F1 A/S on SVT Cobras (OE GT500's), 14" shorty, Wheelskin side scoops & qtr window louvers, A-H rear window louvers, SHR honeycomb blackout panel, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
06 V6: Legend Lime, Pony Package, 14" shorty, Sequentials, Hella Optilux Extreme XY fogs, Silverstars
Nuke is offline   Reply With Quote
Old 10-20-2009, 10:06 PM   #3
Avalanch3
Avalanch3's Avatar
Vehicle: 2007 Mustang Coupe
They don't make that size in the Goodyear Eagle's
BUT, you can pick up a nice set of Nitto 555 Extreme's
http://discounttires.com/product_det...E=&prodID=6767
Pretty cheap too IMO compared to American Muscle which sells them for $157 each.
__________________
Avalanch3 is offline   Reply With Quote
Old 10-20-2009, 10:45 PM   #4
Burrosito
Burrosito's Avatar
Vehicle: 2006 Ford Mustang GT
Not to threadjack, but was wondering, if I got 20" rims, would any speedo correction be necessary? I currently have the stock 17's.
__________________
Stock!
Burrosito is offline   Reply With Quote
Old 10-20-2009, 11:22 PM   #5
Nuke
2007 Ford Mustang
My Garage
Nuke's Avatar
Vehicle: 2007 GT
Us ethis to calculate your change in tire revs per mile: http://www.1010tires.com/tiresizecalculator.asp
Usually with 20's (fugly, IMO) you'll end up going with a rubber band... I mean, a tire with a very low profile... in order to stay close to the original tire RPMS. Any changes are done with the handheld tuner.
__________________
Rick
Old 10-20-2009, 11:40 PM   #6
Burrosito
Burrosito's Avatar
Was just wondering. It'll be a while before I get rims and tires for my car, so I'm not too worried about it. Probably will decide between 18's and lots of rubber or 20's and clean style without lowering. Both look good IMO.
__________________
Stock!
Old 10-21-2009, 01:11 AM   #7
jahudso2
Send a message via AIM to jahudso2
I have read good reviews for the summitomo htr zIIIs and they are dirt cheap on tirerack.com. they are probably my next tire. I am trying to decide whether to get the 235/55/17s or 255/40/17s. One benefit of getting slightly smaller tires is the increase in effective gear ratio you get.
__________________
2008 GT Manual
JBA Ceramic Shorties
Pypes O/R H-Pipe
Corsa Axle-back
FRPP 3.73s
D-Specs
Stillen Sways
J&M LCAs
Join us in the NC Mustangs Social Group.
jahudso2 is offline   Reply With Quote
Old 10-21-2009, 02:17 AM   #8
Avalanch3
Avalanch3's Avatar
Quote:
Holy hell, this isn't slightly smaller tires, those tires are a whole 2 inches smaller.. With that, you will have another 2 inches of gap between your fender and your car will be lower to the ground by 2 inches, making it easier to scrape..
The diameter difference is alost 8% with those tires and 3% should be the MAX in change because the car was designed to have a 27 inch wheel diameter.
__________________
Old 10-22-2009, 01:19 AM   #9
jahudso2
yeah, so you lower your cg and get a more aggressive gear ratio at the same time. i'm not saying its the best way to do it, but is probably the cheapest.
__________________
2008 GT Manual
Pypes O/R H-Pipe
Corsa Axle-back
FRPP 3.73s
D-Specs
Stillen Sways
J&M LCAs
Old 10-22-2009, 08:14 PM   #10
nemosgt
Vehicle: 2006 Mustang GT
Quote:
Hi guy.
You will have to stay with the 27" diam. or so to avoid speedo correction.
With 20" rims you will have a harder ride and more chances to damage your rims on curbings etc.
Chevy Convert:
The only tires I could find at 255/50/17 were the Nittos or Fuzions. Not much choice in this size to maintain a 27" diam. I went with the Fuzion ZRi and was completely satisfied. Even tracked them.
Now using the Shelby500 18' take-offs which look sharp, handle well and are reasonably priced.
Cheers.
nemosgt is offline   Reply With Quote
17, 2005, 2006, 2555017, classic, conversion, ford, gt, inches, model, mustang, mustangs, size, sizes, stock, tire
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
