Quote:
Originally Posted by Rubrignitz
Thoughts on these or has anyone installed them? The horror stories of failures and extreme nvh with tubular arms has me skittish and I've ruled out tubular CA's for street use. I still have a bit of vagueness in my front steering response and think these may be the answer.
http://www.steeda.com/products/steed...m_bush_kit.php
I will tell you first about the Bmr contol arms ......I have seen a failure at willow springs but also I know a few people who have been using them for a few years with out any problems . So it depends if you get a Tuesday set of a half ass Friday set (lol) also I dont know if the Steeda x-5 ball joints will fit in them because there pretty thick around the hole where the x-5 goes in I know on the stock arms when the x-5 goes in it flares out the hole because its alot thiner there ? (something to think about )
as far as those Steeda inserts go I think if you have the Steeda sport springs they help out but when going with stiffer springs like I havee on my coilover set up I really didnt notist anything and I used the black bushing ...there was a pick up on NVH . Im sure if you do some testing with them over all they help.
Now Steeda offers another bushing set up ..it replaces the stock fluid one (219.00) Steeda says race only because it really gives you alot of NVH. Its basically the same piece thats on the BMR arm .....but the performance you will gain is alot in turn in and braking ! I have took a ride in a car with the BMR front control arms (poly) version and I didnt think they were bad and thats was with a 275-40-18 tire .
Hey go over to the s197 forums and go on the Corner carver section alot of good people over there including myself , they might be able to help you out a little better .
