Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-22-2009, 10:30 PM   #1
Ken04
Ken04's Avatar
Vehicle: 2006 V6 pony,2005 GT
Default wheel hop versus wheel,,,,BANG ?
so I pulled on the street today, dry pavement, in 1st gear. I roll on the throttle til about 3 grand then nail it. As I powershifted into second I got no chirp, no hop, nothing but 2 real loud BANG-BANG's right in a row. Looked behind me to see if I had rolled over a steel plate or something, but there was nothing there. So,, it was odd. Sounded like it came from the rear end area, heard it more than felt it. Car drove fine on the way home. 05 GT, 5 spd manual, 3:31 gears, all stock. (I thought ALL the 05 GT manuals came w/3:55's?)
__________________
her car; SMR #0951 06 V6 Pony, manual, mycolor, Shaker 1000, BMR lowering springs, adj track bar, center fog grill, 10" stripes, side window louvers, GT wheels. Pypes Violator cat back. Tri-bar grill emblem. GT500 splitter, rocker stripe delete, FIA/Shelby stripes, smoked front signals. FMC hood scoop.
My car, BMC #12073 black on black leather 05 GT. Manual, Shaker 1000, Shelby FIA stripes, NSP stainless axlebacks, Pro 5.0 shifter, Xenon window scoops.
Ken04 is offline   Reply With Quote
Old 10-23-2009, 08:34 AM   #2
Argonaut
Argonaut's Avatar
In 2007 when I bought my GT the 3.55s were an option. I think they became standard the following year.
If everything seems fine now then maybe you rolled over something or kicked something up into the wheel well.
__________________
07 GT 5spd: stock > road racing > stock.
Argonaut is offline   Reply With Quote
Old 10-23-2009, 09:31 AM   #3
pascal
S197 Section Modder-ator
pascal's Avatar
Vehicle: 06
Could simply be your exhaust if you have tight tolerances.
Power shifting occasionally rattle everything around, so it moves more than you think...
__________________
pascal is offline   Reply With Quote
Old 10-23-2009, 10:48 AM   #4
rdsx18
2005 Ford Mustang
Vehicle: 2005 Mustang GT
05 5 speed GT's had 3.55's IIRC. Then after that I think it was an option. Check your axle code (found inside the door jamb) and try to find a list of the explanations on here. As far as the noise, I have had wheel hop and it was never like that, but like pascal said it could've been the exhaust hitting when you powershifted.
__________________
2005 Redfire GT
rdsx18 is offline   Reply With Quote
Old 10-23-2009, 12:22 PM   #5
Ken04
Ken04's Avatar
Quote:
I saw the 3.31:1 tag when I was under it swapping out the axlebacks. I was pretty surprised as I thought all the 2005-06 GT manuals had the 3.55's. So I'll have to go w/the 3.73's now whereas I would have left the 3.55's in there.
Yea must be either something I hit, or something flopping around. I thought maybe it was the UCA or the stock LCA's flexing or bending. It sounded exactly like when an axle lets go. To hear it once would be one thing, but these were two loud bangs right in a row, like a left axle then right axle, almost simultaneously. Or something flexing the rebounding. The last time I grabbed second like that the car was a little sideways in a turn, so it kicked out about 3 feet. Scared the pee outta momma, haha.
Well if it's not a common thing I'll get up in there and see if there's anything loose. I bought this as a real low mile, well cared for car that some lady owned. Didn't have a single mod on it. But it definitely has some serious wheel hop so I guess it's time to shop for an UCA and a couple LCA's.
__________________
Old 10-23-2009, 03:38 PM   #6
rdsx18
2005 Ford Mustang
I just got BMR LCA's and haven't had wheel hop since. That's my only suspension mod. Also, I'd still go with 4.10's, unless you do a ton of highway driving. I try to avoid the highway so 4.10's was an easy choice for me.
__________________
2005 Redfire GT
Old 10-23-2009, 03:41 PM   #7
Sam Strano
Sponsor
Sam Strano's Avatar
That's wheelhop.... Common with these cars @ stock height. LCA's generally fix it right up. I carry UMI, Steeda, and Maximum Motorsports arms. Shocks can help with that issue from a roll because the axle doesn't always move forward and back, but up and down which can cause hop too. The fact it felt like you hit something is more indicative of a damping issue than the LCA's.
Could have been a bump, could have been small. The shock to axle when you slammed 2nd and the subsequent wheel spin can cause the axle to shudder and jump around with the slightest provocation.
Bottom line, shocks could well help and would help ride and stability in general. The quick way to really fix wheelhop (which is different than the hop that skips the car around when you hit bumps) is an set of LCA's that don't have soft squishy bushings and flex built in. It's worth noting that in general, a lowered car with stock LCA's doesn't hop. Mine completely quit wheelhopping when I lowered it with no other changes. The Koni's helped tame some of it themselves but never stopped it.
Here my page that has all the S197 LCA's I carry listed. UMI parts are available in either black or red (and it very good stuff).
__________________
Strano Performance Parts
www.stranoparts.com
814-849-3450
SCCA National Champion (x6)
SCCA ProSolo Class Champion (now x5)
SCCA ProSolo Overall Champion 2009
Sam Strano is offline   Reply With Quote
Old 10-23-2009, 04:30 PM   #8
Ken04
Ken04's Avatar
thank you Sam, great info. With 6 kids I have to be pretty careful around Christmas. But tax time, yea baby. I'll be sure and look you up.
__________________
Old 10-23-2009, 05:38 PM   #9
Sam Strano
Sponsor
Sam Strano's Avatar
Glad I could shed some light...
__________________
www.stranoparts.com
814-849-3450
Old 10-24-2009, 02:57 PM   #10
Ken04
Ken04's Avatar
you were helpful, thank you. But, inquiring minds want to know; so, after you lowered your car, you had no more wheel hop correct ? I have our 06 lowered and although I never noticed because my wife didn't drag race it until after I lowered her car, that she had no wheel hop either. I assumed the 3 link was responsible for that. Maybe not ? So by raising the mounting point of the forward end of the LCA, that eliminates wheel hop ? So why do people install LCA relocation brackets ? I understand the theory of the bar being straight for better launches, but this seems to go against that ?
__________________
2005, added, avoid, car, gt, hop, hopping, lcas, link, mustang, spin, spinning, wheel
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
