Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-24-2009, 04:24 PM   #1
Darren05
Darren05's Avatar
Vehicle: 05, Mustang GT
Default Drag & DD suspension
My mustang is my daily driver and I like to take it to the local track every once in a while. I am wanting some springs that would not lower my car and if they did, not much, that would be good for traction at the track. Also, shocks and struts. I run 275-40-17's on the rear on 17 X 9 wheels. I am going to need some brakes also pretty soon and would like to get some new brakes, rotors, and calipers that will fit in a 17" wheel. Any suggestions?
__________________
05 GT,5-spd.
Performance Mods:
Pypes H-pipe,Flowmaster axle back,
C&L CAI, SCT w/Brenspeed tune,3.55 gears,
Steeda Delete Plates,BMR LCA's
Exterior Mods:
Steeda hood, UPR billet hood pins, Stallion spoiler,
Hot Wheels 17X9 wheels, Billet Grill
Darren05 is offline   Reply With Quote
Old 10-24-2009, 04:43 PM   #2
07CaliGTstang
07CaliGTstang's Avatar
Vehicle: 2007 Ford Mustang GT/CS
For springs, I suggest the Steeda Ultralites. Only lowers the car an inch. Lowering your car will effect your drag times, especially your 60's. Just FYI.
For shocks i recommend the adjustable Tokico's.
My car is pretty close to being a DD and I take it to the track as well. I would look into getting some LCA's also. They will help with wheel hop when coming out of the hole.
__________________
The Real "Laura" Croft
'07 Performance White GT/CS
All SHOW and a little GO!!
NEW BEST 13.4 @ 103MPH
07CaliGTstang is offline   Reply With Quote
Old 10-24-2009, 07:02 PM   #3
Sleeper_08
2008 Ford Mustang
Sleeper_08's Avatar
Vehicle: 08 Mustang GT
Quote:
Why do you feel you need to upgrade the rotors and calipers?
Even for road course track users the normal recommend is better fluid and pads and then SS lines and if you are on tracks with a lot of braking then front brake cooling.
__________________
White 08 GT Roush S/C 445 HP/KDW2 285/40/18 tires/18 x 9.5 Steeda Ultralite wheels/ Steeda Competition springs/D Specs/FAYS2 Watt's Link/LCA/Adj UCA & Mnt/Upper strut mnts/GT500 Brake Kit/GT500 Front LCA/X5 Ball Jnt/Bmp Str + more
Sleeper_08 is offline   Reply With Quote
Old 10-24-2009, 08:49 PM   #4
Darren05
Darren05's Avatar
Just figured slotted rotors with better brakes and calipers would last longer than the stock set up. If not, I wont do the upgrade.
__________________
05 GT,5-spd.
Performance Mods:
Exterior Mods:
Old 10-24-2009, 08:55 PM   #5
Darren05
Darren05's Avatar
I have the lower control arms already. I will be running 275-60-15's on 15 X 8 wheels at the track. That will effect my e.t's and 60's more than springs will. Just wasn't sure if that would fit with lowering springs. Was curious if there was a performance spring out there that didn't lower the car. If not, I would want the least amount of drop. As for the shocks, i've been looking at the D-spec's like you suggested, just wondering if there are any other adjustables out there with a good rep. Thanks for the input.
__________________
05 GT,5-spd.
Performance Mods:
Exterior Mods:
Old 10-25-2009, 11:42 AM   #6
Ken04
Ken04's Avatar
Vehicle: 2006 V6 pony,2005 GT
the Cobra Jet Ford drag car comes with stock, V6 springs in the rear. You won't lose any ride height, your tires will fit and it should help your 60' times. And they're cheap and abundantly available. Those and your shocks and LCA's, you're set.
__________________
her car; SMR #0951 06 V6 Pony, manual, mycolor, Shaker 1000, BMR lowering springs, adj track bar, center fog grill, 10" stripes, side window louvers, GT wheels. Pypes Violator cat back. Tri-bar grill emblem. GT500 splitter, rocker stripe delete, FIA/Shelby stripes, smoked front signals. FMC hood scoop.
My car, BMC #12073 black on black leather 05 GT. Manual, Shaker 1000, Shelby FIA stripes, NSP stainless axlebacks, Pro 5.0 shifter, Xenon window scoops.
Ken04 is offline   Reply With Quote
Old 10-25-2009, 04:26 PM   #7
07CaliGTstang
Yep, was going to suggest that Ken........thanks.
__________________
Old 10-25-2009, 10:03 PM   #8
Darren05
Darren05's Avatar
Thanks for yall's help. Excellent suggestion, I never would have thought of that.
__________________
05 GT,5-spd.
Performance Mods:
Exterior Mods:
Old 11-10-2009, 07:56 PM   #9
desslok40
I just upgraded to centric premium rotors. hawk HPS pads, I had warped my stock rotors due to power breaking at the track , for drag racing you need thicker rotors with better pads, slotted and drilled may look cool but thats' less surface area for pad to make contact, also slotted/drilled are more suited for road racing as you are constantly on the brakes and cooling is a bigger issue.
__________________
2006 GT - AUTO
Performance:
C&L Racer, SLP LT Headers , X-Pipe w/ CATS
3.73 FRPP Gears, BMR LCAs, GMS UCA
BORLA Stingers
Looks:
3D Carbon Spoiler
CDC Trim Panel w GT Logo
13.3@103.42 1.96_60ft
desslok40 is offline   Reply With Quote
Old 11-11-2009, 12:52 PM   #10
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
Quote:
Better pads should be sufficient.
Nope.
Drilled rotors are far more likely to crack from the huge amounts of heat generated extremely rapidly and repeatedly in the road-racing environment. The original reason for drilling rotors had to do with the pads generating lots of gas at high temperature and actually floating the pads off the rotor surfaces. It isn't much of an issue any longer given appropriate pad choice; the severe thermal transients are.
I suspect that going with softer rear springs will eventually have you looking for better shocks, LCA relocating brackets, or both.
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
body, dd, drag, fox, good, mustang, setup, suspension, tuning
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
