Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 10-25-2009, 09:57 PM   #1
shakrr
shakrr's Avatar
Vehicle: 2009 mustang gt convertible
Default need suspension chang
I have a 09 gt convertible with a cervinis kit with stock suspension I want to lower this I don't like the nose up down when acc and braking I have 20s with 255 35zr 20 tires it handles the on off ramps and any twisty s I can find nice, and the clearance on steeper drives su*ks it is only about 5" clearance I read the lowering thread and still don't know what to do, I am thinking 1" rear only with adj shocks and stuts will this stop the rocking horse? am i close or do I need to spend more for a air ride.
shakrr is offline   Reply With Quote
Old 10-26-2009, 12:53 AM   #2
jahudso2
Send a message via AIM to jahudso2
If you are close to scraping already, i would try adjustable shocks/struts first. I run the stock springs with tokico d-specs and can tell a huge difference in pitch and dive during braking and accelerating when running the dampers stiffer than stock.
__________________
2008 GT Manual
JBA Ceramic Shorties
Pypes O/R H-Pipe
Corsa Axle-back
FRPP 3.73s
D-Specs
Stillen Sways
J&M LCAs
Join us in the NC Mustangs Social Group.
jahudso2 is offline   Reply With Quote
Old 10-26-2009, 01:28 PM   #3
Norm Peterson
2008 Ford Mustang
Norm Peterson's Avatar
Vehicle: 2008 GT Premium
If you only notice this when accelerating and braking, better dampers will slow the motion down but not necessarily reduce how far it actually travels. IOW, you'll still be likely to scrape, just not quite as often.
If you lower the car, it sounds like you will absolutely need more spring rate.
You shouldn't be getting much of this "rocking horse" motion while just driving at a steady speed, even over roads that have evenly spaced "heaves" in the pavement. If you do, that wouldn't say much for either the OE dampers or spring rates (and I doubt that Ford managed to get them that far off). Or it would say that you've managed to trash them in pretty short order.
Norm
__________________
08 GT Premium Black/Light Graphite, stick, un-FStock
weenie-EP 626/V6/stick, Prepared just enough, sometimes
Norm Peterson is offline   Reply With Quote
Old 10-26-2009, 01:44 PM   #4
Sam Strano
Sponsor
Sam Strano's Avatar
I'd suggest a good set of dampers. The rocking and hobby horse motion is less about the spring rate, and more about the lack of body motion control so the car doesn't settle down.
D-specs are an option. I carry those $569/set shipped. Koni STR.T's if you don't want adjustables are now $409 a set (not shipped, about $25-30 to ship them). There are Koni Sports which are better than D-specs. They cost most @ $780/set and we are stil waiting on a shipment of fronts which is taking forever.
Links:
D-Spec set: http://www.stranoparts.com/partdetai...D=64&ModelID=5
Koni STR.T set: http://www.stranoparts.com/partdetai...D=64&ModelID=5
__________________
Strano Performance Parts
www.stranoparts.com
814-849-3450
SCCA National Champion (x6)
SCCA ProSolo Class Champion (now x5)
SCCA ProSolo Overall Champion 2009
Sam Strano is offline   Reply With Quote
Old 10-26-2009, 05:44 PM   #5
shakrr
shakrr's Avatar
this is a new car less than 1000 miles the rocking horse is from me smashing the gas and playing this is a toy for me not a dd i do want to lower the rear it is way to hi and would like to lower the front a little but not a 1", I like the looks off the stalker package cervinis has in their ad lowered they say they install a German brand springs voitl something that is .75 in front and 1.25 in the rear and they end up with what i have now almost 5" in the front does that sound right?
Old 10-26-2009, 06:14 PM   #6
Sam Strano
Sponsor
Sam Strano's Avatar
You seem to imply that becaue the car is new the shocks can't possibly lack body control (which is rebound damping?).
It's not that the car moves up and down, it's that it happens too quickly. And fwiw, most of it is the up when you hit the gas hard and the fast drop when you jump off it. Stiffer springs won't help the "up" much at all, will help the "down" some. But then if you don't do shocks with the springs the ride will suffer, and will get worse with time, along with more pronounced body motion as the shocks just get overwhelmed by the higher rate, shorter travel springs.
__________________
www.stranoparts.com
814-849-3450
Old 10-26-2009, 07:13 PM   #7
shakrr
shakrr's Avatar
I want to do adj shocks also I mention the konis cause you said they were better in another thread, do you know the german springs they told me about i like the .75 drop up front with 1.25 rear which they say is stiffer than eibachs will dropping the rear more bring the front back up a little from the angle
Old 10-26-2009, 07:48 PM   #8
Sam Strano
Sponsor
Sam Strano's Avatar
Nothing specific. German means Eibach, H&R or Vogtland. I sell all 3, none have a listed set of that drop, but using GT500 springs will lower the nose less (since GT's have less weight) and I estimate those spring to be about a .8" front, 1.2" rear drop. In fact, here's the link to them on my site (with a pic of a Bullitt on them): http://www.stranoparts.com/partdetai...D=75&ModelID=5
I'd also ask you to consider what information you gather where. I ask this because lately there has a been a rash of folks wanting knowledge I have and worked for, then running off to buy things other places for little difference in price.... I don't see Cervini's in here doing that. Hell, seems they don't want to even tell you what springs!
__________________
www.stranoparts.com
814-849-3450
Old 10-26-2009, 08:24 PM   #9
shakrr
shakrr's Avatar
thanks sam will call you in am to discuss
Old 10-29-2009, 04:47 PM   #10
shakrr
shakrr's Avatar
wow that was quick all the parts showed today Sam
__________________
Cervinis stalker kit w/ram air, kooks long tubes w cats, Bassani axle back, Anderson power pipe w/dbx97mas, TCI Ratchet shifter, 4.10s, 20 boss w/255 35zr, steeda adj coil overs, tokico d-specs, umi adj phb
koni, reviews, strt
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
