Roush Trak Pak
you realize that is only shocks/struts + springs + caster/camber plates right?
hardly worth $1,500 + shipping.
it doesn't even include better sway bars. You can do at least as good if not better with other products and for at least $500 cheaper.
Hell, you can grab GT500KR shocks/springs for $400. Lowers you over 1" at the same time.
this suspension also doesn't include control arms, brackets or a panhard bar.
if you want a car that will handle, get the parts/pieces elsewhere IMO. You can fully replace your entire suspension with better components that will make the car handle 100% better for less money.
yep, I oversimplified the kit. But what I said is true. You are paying in triple if not quadrouple the price for some coil-overs...aka shocks/springs. And not the best ones at that.
all so you can change the ride height occasionally. I personally would get the front height set at a certain hieght and never touch again. Then maybe buy 2 different sets of rear springs. one set for street, one set for strip. take you 5 minutes to swap out and you save 1/2 the price.
yes, the KR springs are for a 5.4 4v motor.
I'm still trying to find out if the 200-250 lb differenece will have a GT riding higher up front compared to the way a GT500 would sit.
It's a 1" drop on the GT500 when you install the KR shocks/struts/springs...which is why I'm considering the swap. That, and you can get the entire GT500 KR front/rear assembly for under $400 right now
http://www.buyfordracing.com/
if you have your heart set on the Roush setup, cool. Just wanting to point out that there are better setups available for cheaper. Especially as you will still need at a minimum lower control arms, panhard bar, relocation brackets, sway bars if you plan on racing the car in such a manner that would justify the Track Pack
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
mungodrums
09-28-2015 10:54 PM
