Go Back   MustangForums.com > Ford Mustang Tech > 2005 - 2011 Mustangs > S197 Handling Section
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-07-2009, 08:39 PM   #1
shakrr
shakrr's Avatar
Vehicle: 2009 mustang gt convertible
Default any ideas
I installed the steeda adj coil over shocks and struts 175 rear and 200 front on the springs also adj phb. I cant get the RR height higher than the RF I even made a 1.25 inch spacer mounted above the top of the rear coil thinking this would get me close enough but when I raise the RR the LF drops or raise the LF the RR drops I am now at
LF adj all the way up
RR adj all the way up plus 1.25 spacer
LR adj all the way down
RF adj all the way down
shouldn't i be able to adj each corner or without affecting the opposite corner my car started out stock RR .75 higher than the other 3 corners is it twisted? going to get it aligned wed I tightened the rear shock bolt withe car on the ground
__________________
Cervinis stalker kit w/ram air, kooks long tubes w cats, Bassani axle back, Anderson power pipe w/dbx97mas, TCI Ratchet shifter, 4.10s, 20 boss w/255 35zr, steeda adj coil overs, tokico d-specs, umi adj phb
shakrr is offline   Reply With Quote
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
