Cutting Rear springs...to level the car...(not a newb at cutting) but...
#31
I dont believe any part of this is true. And Im pretty sure the second part cant get any more wrong if it tried.
#33
What, you guys don't occasionaly Hazard it up over some train tracks or something? Pretty sure I unload my suspension over some dips and such on a monthly basis.
Also, who am I to question the Gods of the MFers in this thread, but if I have read the previuos posts correctly, heating the springs changes the carbon levels in the metal which makes them more brittle. Heating them while on the car and just letting the car settle lower seems like it would just leave you with some brittle rear springs. Think I'll stick with my Steeda/Tokico plans.
Last edited by JFitz; 10-28-2012 at 08:14 PM. Reason: Because I'm an idiot sometimes
#34
FYI: Rear roush springs lowered my 12 GT TOO MUCH. I have brembo as well, but the rear sat .25" lower than the front.
#35
The heating idea was a joke. So wrong in so many ways it
was designed to seem pretty silly.
The idea to be conveyed was to just buy proper lowering springs...
But if you must, 1 coil equals roughly 2" of drop.
So chopping 1/2 of a coil should be safe from drop-out at full
suspension extention.
#36
Personally, I've never considered heat for lowering as it ruins the temper in the spring .... but I have cut springs.
Of my current fleet, my '92 T-bird Sport rides a bit lower and does so very comfortably and stable like with 1 coil cut in front and 5/8 coil cut in rear "Sport" (JJJJ) springs with Tokico Blues. Yes, spring rate was increased some, but the shocks handle rebound well and car hasn't bottomed out, ride is stiff enough, corners flat too. I also only cut from the open end when I did it.
We just bought our 2008 GT in June, I like it ..... but I am a bit annoyed with the excessive rear gap over the tire at top ..... "fender gap". I have no desire to drop the whole car as I drive in the real world, just want to bring the back down about 3/4". I also notice in driving that the car has a feel of understeer to it, the front feels heavy, it seems to like straight better than hard right or left. To me this says it would respond favorably to a slight increase in rear roll resistance .... either through slightly larger rear sway bar .... or slightly stiffer rear spring rates. A slight trimming of rear springs will increase rear spring rate slightly, maybe not noticeably, but still it is a step in the right direction.
http://www.eatondetroitspring.com/cutting-coil-springs/
#37
OK ....... so last night I bid on some Roush rear springs, I wasn't willing to go but so high ..... but I did drive a bidder up. I wasn't willing to spend $123.99 on rear springs for an inch just yet so I didn't.
Today I did all that one must do to safely remove and cut and reinstall our 2008 Mustang GT's rear springs. This morning before I started I again measured the distance at each fender opening from carport to top of fender arch at maximum, fronts were 28-1/4" and rears were 29-3/8".
My goal was to eliminate at least 3/4" in the rear and not need a panhard bar change.
I cut using a Dremel tool with a fibreglass HD cutoff wheel. I read of people worried about heat .... and often resist the urge to respond. The spring end last half inch got a little bit warm, but not even uncomfortably so, the cut is so small and narrow and weighed against the mass of the spring, does not get the steel hot. I cut one full coil off the top end of the coils plus an inch which was where I marked using a 1" wide rule against the spring end. The Dremel HD cutoff wheels last and even after cutting two springs the wheel shows minimal wear, just take it easy.
After I was finished, I took a short drive and then I measured again in the same spot on the carport, and I am glad I did not cut more! Imagine my surprise to find that now all four fender tops, front and rear, are each 28-1/4" from the floor. All 4 the same, and just a hint of rake along the lower edge of the rocker panels.
(I only posted left side pics, I have all 4 though.)
I checked to see if I needed to work any on the panhard bar, had decided if within 1/4" I'ld leave it alone .... with a straight edge from fender down to tire sidewall bulge (rear tires at 33 psi) the gap to upper sidewall is "near the same".
Before:
After:
I think it looks great, certainly worth the time spent and $$$ saved which is like "earnings" as opposed to what I would have done had I won that bid last night ....
#38
Have you considered fabbing up a spacer of 1/4" or maybe 3/8" thickness? I'd use steel.
You should put such spacers or shims at the ends of the spring where you made your cuts, and incorporate some means of positively locating the spring such as welded-on locating lugs, tabs, or a ring sliced from a piece of exhaust tubing. Don't forget that without the small diameter end coils the spring is no longer as positively located at the cut end as it was in the all-OE configuration.
I've done this sort of thing before.
Norm
Norm
#39
On 10-19-13 I decided to double check my side to side centering with a level and plumb. I was pretty sure it was OK but I had already (before even yesterday) decided if I found it off much, instead of an adjustable PHB, I'd just move the stock hole a little bit on one end (example being that if one side had been 1/4" more or less than the other, 1/8" movement would correct it).
I placed a level across the spoiler top and found it level, checked carport floor and it was level under rear bumper, so I hung a short string with weight from each fender top at center and measured from string to tire sidewall .... driver's side just a hair under 3/8" but over 5/16" (about 11/32"), passenger side right on 3/8" mark (12/32") and that's "pretty darn close" to being the same.
Funny you should mention ` .... I came really close to taking a (say two) piece of 1/8" sheet cut into a circle to fit inside the stock perch up in the frame, as you know it's in a deep upside down well. I was thinking maybe putting a sheet of inner tube rubber between it and the car frame metal. The stock upper spring isolator just snaps out (almost falls out) and I was going to maybe use a plastic snap in retainer (like used in so many places on cars now) to hold it in place in same hole while spring is inserted.
Then on the spring side of the sheet, was thinking maybe build up a half circle gradual ramp maybe rising 3/4" total in 180 degrees with a 3" center pretty much as you describe. It would be really easy to make. Not so needed for keeping spring in but more for a better seating.
I may still do it one slack day.
I looked at the stock spring isolator, it's pretty thick, and so I gave it a try as is, there is no way it can jump out as the spring is still snug when shocks are fully extended and that's a deep well and the lower end of the spring sitting on the axle is un changed. I did look at the angles between the axle perches and the floor of that upside down well and after thought, decided best to put long side of spring towards rear of car.
See below for more:
Norm
Norm
See below for more:
#40
Today (10-22-13) while delivering parts I had some time to think (some parts runs are out into the county and last an hour or more) and suddenly I recalled a bunch of 89-97 Thunderbird rear spring rubbers I had in a box, and they have a built in ramp and step to seat a coil with open ends.
I got home after work, pulled the Mustang around onto ramps, jacked and set frame on padded stands, and removed ramps and undid lower shock bolts and eased axle down with jack and removed the coils I had cut a few days ago. No permanent bends yet and we drove them over 250 miles Sunday alone on a not smooth roadway.
Mustang springs are about 3.5" ID, the T-Bird springs in a 89-97 Thunderbird rear are about 4" ID, the rubber snap into the coils. I modified them a bit .... cut a section out where the two tie wraps are closest. I then reinstalled the springs with the pigtail part of top towards rear of car, centered in spring seat with new T-Bird rubber between spring and Mustang Rubber with center bumper.
Where immediately before todays "spring seat rubber" mod the top of the rear fender arches were 28.25" from floor, afterwards they were nearer 28.5" .... a gain of just under 1/4". That's still a good full inch below where they were and that's OK. I was looking through pictures from Sunday, with camera gear and tripod and tool kit and stuff in trunk, the rear was maybe 1/4" low anyway?
See what I mean .... a good 1/4" low in back loaded then, so the added 1/4" won't hurt.
