Scrubbed R comp. tire wear
Old 01-10-2010, 11:00 AM
blksunshine
blksunshine's Avatar
Default Scrubbed R comp. tire wear
For those of y'all that use them, how far do you wear them down before discarding? Top of the wear indicator, bottom, etc?
thanks
blksunshine is offline
Old 01-10-2010, 03:29 PM
jayel579
jayel579's Avatar
"scrubbed" tires have usually had 1 heat cycle through them to break them in, from there it depends on what tires are they. Every tire is different. R-comps aren't street tires so you really cant measure there life expectancy by the wear bars. It is going to come down to how many heat cycles have been through them and how there performance falls off from there. Some have long life spans, meaning they go through a large number of heat cycles some have short life spans with fewer heat cycles.
jayel579 is offline
Old 01-10-2010, 07:10 PM
blksunshine
ok, thanks
Old 01-10-2010, 08:19 PM
Argonaut
Argonaut's Avatar
Most hard core track junkies will either run them until they see a cord or until they get to hard and loose all grip.
Argonaut is offline
Old 01-11-2010, 03:27 PM
EdwardGT
EdwardGT's Avatar
I run my tires until I see cords.
EdwardGT is offline
Old 01-11-2010, 05:00 PM
Sam Strano
Former Sponsor
Sam Strano's Avatar
I can't run to cord on Hoosier's, they lose all grip before that. Now if you are cording the shoulders, that's different (and indicates a setup and/or driving issue). I get very good tire wear, tend to wear the centers out before anything due to the tire I run on the mandated (in the class) stock rim size.
Sam Strano is offline
Old 01-11-2010, 05:21 PM
EdwardGT
EdwardGT's Avatar
I'll almost invariably start to show just a little bit of cord at some point, i.e. smaller than a dime-patch. I rotate my tires front to back halfway through the day or weekend since my fronts usually seem to wear more in the center and my rears seem to wear on the outboard shoulders.
EdwardGT is offline
Old 01-11-2010, 07:10 PM
RodeoFlyer
RodeoFlyer's Avatar
till they pop.
RodeoFlyer is offline
Old 01-12-2010, 10:15 AM
Red06
Red06's Avatar
I run my Nitto NT-01's until they cord. Their performace dosen't seem to fall off much to that point so I check after each session when I know they are getting close.
Red06 is offline
Old 01-17-2010, 09:25 AM
blksunshine
thanks y'all. I'm not at the cords yet and they still felt good last time. Harris Hill here I come!
Quick Reply: Scrubbed R comp. tire wear
