Old 10-23-2015, 05:51 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Ford Mustang GT Steering & Suspension Guides
Print Wikipost
installing front control arm (a arm)
Old 06-25-2013, 01:28 PM
  #21
jsimmonstx
jsimmonstx's Avatar
Originally Posted by moosestang
Bumping an old thread! It's what I do.
Hold the spindle? I left the spindle connected to the strut. I did not move the steering rack. I was replacing the tie rods and the control arms, so I popped the tie rod out and turned the wheel all the way to the right, while working on the left arm. The bolt will come out, you just have to push on the tie rod boot and wiggle the bolt out.
bolt out, no problem.
[...pic was here...]
Replaced tie rod with moog. I used the credit card between the old tie rod and jam nut trick. Screwed the new one on up to the credit card, then tightened the jam nut. Seems to have worked well at keeping the toe close.
At 45,000 miles my stock tie rod boots were torn all the way around, but the tie rods still felt tightish. Ball joints felt good too, but the stock control arm bushings give a lot compared to the gt500 ones.
Resurrection #2:
I'm about to do exactly the same thing - (Steeda) front LCA and (Steeda) bump-steer kit. Got any tips, tricks or hints for me?
Any special tools? I have an electric impact wrench and a 150-ftlb torque wrench (might not be big enough).
Where can I find instructions for front LCA R&R? (My car is a 2012.)
jsimmonstx is offline
Old 05-07-2015, 11:38 PM
  #22
DMPhelan
DMPhelan's Avatar
With my experience, the two rack bolts were very hard to get off. My 300 foot pounds impact wrench did not touch them. On the first nut I had a hard time loosening it up with a 3-foot breaker bar. The other bolt I rounded the threads and had to use a chisel hammer to cut the bolt. If I could do it again I would have loosened the tie rods and move the tie rod to get to the bolt see previous posts. Also is would have used a GearWrench 9921 21mm Flex-Head Combination Ratcheting Wrench for the 4 nuts on the large bushing. I would of saved a least 1 hour in removing and putting them back on using that wrench. Because you can only get at a 1/8 of a turn each try. I bought new rack bolts and nuts at the dealer. Thay gave me the right bolts, but the nuts threads were wrong, make sure you check them. Last thing, make sure you use some type of lock tight on the old bolts to make sure they do not loosen up.
DMPhelan is offline
Old 05-08-2015, 08:07 AM
  #23
waykooljr
waykooljr's Avatar
The rack bolts are removed from above, do not try to remove the nut. You should be able to reach in from the side and over top of the k member to put a ratchet on the bolt, wrench will get in there too.
I went out and bought an impact gun to get the nuts off, when it didn't budge, that was my clue that they're welded to the frame.
waykooljr is offline
Old 10-05-2015, 08:27 PM
  #24
Buck268
Buck268's Avatar
Just replaced a-arms with M-3075-D cobra units and stock length NAPA springs on my '96. First of all, my harbor freight impact was invaluable as usual and made a lot of steps much faster including wheel lugs, BJ nut and tie rod nuts, and especially the front a-arm bolt. But it offered no help on the rear a-arm bolt as I had no clearance to get to either the nut nor the bolt head with it. Perhaps with the right swivels and extensions, but I only have regular extensions and wobble extensions.
Second, this is a Michigan car and I was very worried about the a-arm bolts be seized in the bushing sleeves. NOT AN ISSUE! Somehow. I did make sure to unscrew them from the bolt head side (to make sure they weren't seized) but upon removal the black oxide finish looked basically brand new still :-D
Third. Front a-arm bolts and steering rack. For me the solution was simple and easy. Remove the rack bolts and pop the outter tie rod ends allowing my to slide the entire rack forward. Probably would have even more room if you d/c the steering shaft but as it was I had just enough room to persuade the a-arm bolts out.
For those who are looking to tackle this job, plan two days. The first day will be long and hard as you figure it out on the first side. Day two should be MUCH MUCH smoother. Two more tips. Use MFE's 2-jack method for spring installation! The rear a-arm bolt interfered with my k-member to body bolt. Just spun on the impact and could not find access to the back side. So I just hit the shoulder of the a-arm bolt with a angle grinder. *JUST* enough room to get it in and out that way.
Buck268 is offline
Old 10-28-2015, 01:41 PM
  #25
LordRipberger
LordRipberger's Avatar
I will be doing this soon. Lots of good information in this thread.
LordRipberger is offline
Old 11-03-2015, 09:16 PM
  #26
g150rdt
g150rdt's Avatar
Question
Can anybody tell me what size threads are the steering rack bolts ??. Are they metric or sae. Thank you.
g150rdt is offline
Old 11-04-2015, 07:10 AM
  #27
Norm Peterson
Norm Peterson's Avatar
I'd be reaching for the metric sockets tray first . . .
Norm
Norm Peterson is offline
Old 11-04-2015, 10:10 AM
  #28
Buck268
Buck268's Avatar
The bolts on my 1996 front a-arms took 24mm, the nuts 21mm. This was the same size as the hardware on the 2003 Cobra arms that went in.
Buck268 is offline
Old 11-07-2015, 05:16 PM
  #29
g150rdt
g150rdt's Avatar
Ok, the treads on the bolt are 1.75 mm. Thanks
g150rdt is offline
Granatelli Sales
01-20-2020 12:34 AM
drfister
05-03-2018 10:38 PM
JonnyBlazeGT
11-03-2015 01:10 AM
Cavedawg
09-17-2015 09:51 AM
SYNY5TER
09-02-2015 01:35 AM
Quick Reply: installing front control arm (a arm)
