Enkei RPF1
#22
Yeah I was a little paranoid there for a while and I'm glad things seem to have worked OK especially the centercaps. Snapped right in, no hassles at all. BTW I have to say Brian @ Goodwin - good vendor IMO. Would buy from him again.
I keep having people tell me to lower my car but I've got reservations about it. I drive my car a LOT and the roads here are terrible. It's no garage queen. It sees 4-6000 miles a year on bumpy crappy roads. I don't want to have to avoid speed bumps all the time. And also, if I lower it the right way entails more than just sticking springs on there. Pinion angle could be off at that point and I might need relocation brackets welded in there too. One thing leads to another and if I go down that road it's not going to be simply a set of springs and then done.
if you do drop it just get the rear upper and lower control arms in the adjustable versions instead of the fixed stock replacement versions. that's what I'm planning on getting, BMR make some that look really nice but I'm sure there's others too. that way when you drop the car you can fix the pinion angle and not have any problems.
I'm probably going to get all those rear end parts first, then drop the car. that way I can kill the wheel hop and tighten up the rear and be ready to fix the pinion angle when the car gets lowered.
#23
Thanks for the suggestions. I already have non adjustable LCA and would probably keep them - but replace the third link with an adjustable. That way I have a single point for adjusting the pinion angle if necessary. I would also probably get an adjustable panhard bar and replace the brace as well at the same time.
The Roush rears are kind of attractive to me because it's a mild enough drop that I hopefully wouldn't need to do any of the above but it would even out the gap between the front and the rear which would IMO be nice. I know some here would disagree but IMO the gap on the front isn't bad enough to bother me or looks bad. I'm not real crazy about the extra (1/2"?) gap in the rear though.
Back on topic these RPF1 are obviously a higher quality piece than the Bullitts were. To be completely honest I think I slightly prefer the look of the Bullitts. But they were pretty much junk compared to these new ones. I don't regret my decision now that I have them on the car and things seem to have worked out OK.
#24
just getting the rear adjustable UCA should work, I don't see why it wouldn't.
I agree the rear is the super high part. I personally like the raked look so I'll probably end up dropping the front so there's only a 1/4" or 1/2" of gap and have the rear set so it's about 1/4" more gap than the front.
dropping it even looks good too. the only thing when you drop it even is if you have extra people in the car the rear will end up lower than the front which looks goofy to me.
#27
Riptide,
Thanks for the pics. The wheels look amazing.
Apologies if I missed this info earlier in the thread but if these wheels are not hubcentric, did you have to get sleeves to address this? If so what thickness? Thanks!
#28
I never used any hub centering rings. What I did was take my time and tighten down the lugs in the star pattern and in stages. Finger tight first, then the 1/2" ratchet until snug, then the torque wrench to 60 ft. lbs, then drop the car and finish out to 100 ft lbs.
So far so good. No vibes at highway speeds or any other obvious issues.
#30
Yep 18lb. on an 18x9.5 is gonna be a tough one to beat.
Remember to check the torque on your lugs a couple hundred miles after you first put the wheels on. With aluminum wheels it's a good idea.
