Advancetrac light on 2011 gt
Old 12-16-2010, 08:48 AM
  #21
chrumck
chrumck's Avatar
Originally Posted by Sleeper_08
If you are using the car on the street and car about handling then you should follow Norm's suggestion about using poly only on one end. Using poly on both ends causes the poly joints to "bind" as the car rolls and this affects handling.
Is there a way to upgrade the stock arms to poly and still not to get bind?
chrumck is offline
Old 12-16-2010, 06:43 PM
  #22
Norm Peterson
Norm Peterson's Avatar
Sort of. Do you know what voided bushings might look like?
Norm
Norm Peterson is offline
Old 02-21-2011, 04:28 AM
  #23
jasan
jasan's Avatar
Originally Posted by kkpharmd
the light doesn't just flash. The traction control disabled and stability control disabled lights both come on and stay on and the message center reads "service advancetrac system". this is more than the lights flashing due to my driving or spinning a tire. the only way to get the lights and message to reset is to turn the car off for a few seconds and restart. I'm not sure if the odd feeling coming from the rear end has anything to do with what i am seeing with the advancetrac system. going to the dealer thurs am
Was the dealer helpful? I have the same problem with my car, but I live in europe and it's kind a problem to find a service point here. So what was the problem? Was it serious?
jasan is offline
Old 02-21-2011, 11:58 AM
  #24
nemosgt
nemosgt's Avatar
Yeah. What happened at the dealership? Was there a problem?
Cheers.
nemosgt is offline
Old 02-28-2011, 02:28 PM
  #25
fzaba
fzaba's Avatar
MY brand new GT had the same issue... Service Advancetrac. My problem would rear its head when sitting at a stop light or stop sign. Apparently the "brake switch" had an issue and was throwing up a code. They repaired the switch and it has been fine ever since. Good luck!
fzaba is offline
Old 07-07-2011, 09:33 AM
  #26
StevesGT
StevesGT's Avatar
Was driving my 11 3.7 the other day and had my Advancetrac light start blinking, and my ABS started pulsating, lasted about 10 seconds, not sure it went away because of my slowing to a stop, or it stopped on its own. I restarted the car and all was normal. I have a tune on the car, and this is the second time it came and went in the last 2 months. The first was after I installed the tune the first time. Maybe related?
StevesGT is offline
jwog666
12-27-2021 08:09 PM
4cylinderplus2
10-09-2020 07:45 PM
lincolnshibuya
12-08-2015 04:37 PM
ChampInSD
10-02-2015 04:55 AM
BeatnikFink
10-01-2015 08:00 PM
Quick Reply: Advancetrac light on 2011 gt
