Panhard vs Watt's Looking For Detailed Info
#112
I totally agree. After reading up on teh S197 chassis on other various sties and forums, I have now come to the conclusion that the S197 has so much more handling potential locked away in it. The only thing holding back the potential is the OEM's lack of performance. It seems like Ford went too much on avoiding NVH instead of adding more to the performance side.
After reading up on Watt's Link here and in other places, I have come to the conclusion that it is a superior option to PHB. Though it adds considerable more weight to the car than PHB, at least that weight addition is to the rear of the car. That helps being the center of mass back, for a slight increase in better weight distribution (however slight that weight re-distribution might be).
#113
Actually JiM, the Pumpkin roll center watts link designs such as my Techco and the Whiteline adjustable roll center design are lighter than fords heavy stamped pig iron bar and brace. When I held my stock bar and brace after originally having my Steeda Adj. Pan hard and brace put on, those things were heavy.
Even my Steeda set up was 8 pounds heavier than my Techco Watts link kit. Some sheet metal is removed also when you get rid of the Pan hard bar set up. Erik
#114
Anybody know how much of the weight of Ford's PHB is from the NVH shot that it is filled with?
At 1700+ lbs or so rear weight, an 8 lb difference between the two Watts link designs sounds like a wash to me. Short of playing at the pointy end of some competition class, anyway.
I doubt there's even that much difference in the contributions to unsprung mass. Might as well worry about where on the axle the weight differences actually show up if we're going to worry about a small difference in the total.
I'd make the choice whether to go with a chassis or diff mounted main pivot based on other criteria, for which there probably isn't a fixed answer for all situations.
Norm
Norm
#115
ford could really easily improve on the track pack and not spend much $
#116
OEM engineers will always be concerned with increased NVH, it's almost taboo to develop a high NVH vehicle from the factory. That being said, we (Whiteline) do not believe performance should be sacrificed with NVH. You can have all the performance you need without suffering from noise, vibration, and harshness.
Our Synthetic Elastomer Bushings allow us to design features into the bushings to give you all the performance capabilities and maintain OE ride integrity. We've really tried to engineer a 90/10 formula of 90% of the optimal performance at the compromise of 10% decreased ride quality.
Norm
Norm
#117
Andy1386, Isn't the whole point that a "Track Pack" would imply that the driver would be willing to have a stiffer suspension and chassis, the improved springs, shocks, sway bars, adjustable caster/camber, Watts link and rear LCA's.? Plus wide properly off set wheels and 285/40/18's all around. Totally possible and doable by Ford.Not going to happen because it's Ford.
Mean while Chevy does exactly those things to the Camaro, and it works beautifully. Erik
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
